What do you get with a shackle flip?
Discussion in 'The Garage' started by odoa3, Apr 13, 2004.
  1. odoa3
    odoa3 1/2 ton status
    Mar 31, 2004
    1,638
    Anchorage, AK
    Newbie question! Can someone explain the reason for doing a shackle flip? What do you get out of it? Pro's and con's of doing this? I have been seeing this done alot on here and thought I would figure out if it was for me /forums/images/graemlins/dunno.gif Thanks
  2. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    You net about 4" of lift. There's not many cons, except it can sometimes be a little unstable. If you order one from ORD you should have no problems with it though. /forums/images/graemlins/thumb.gif
  3. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    you get either 2.5" or 4" of lift, same ride as before unlike swapping springs and becoming stiffer, no blocks so axle wrap is not there, and it is relatively cheap to do.
  4. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    I bought mine from ORD. Pretty simple to do. spend the extra money and buy the greasable bushings too! /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  5. PerdidoK5
    PerdidoK5 1/2 ton status
    Jun 10, 2002
    108
    Pensacola, FL.
    Is there a shackle flip for the front also, or only the rear? (Are new springs the only way to lift the front suspension?) /forums/images/graemlins/ears.gif
  6. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    The front is already setup like that, shackle hanging down in rear. It is recommended to use springs up front to keep your caster the same , and for safety. /forums/images/graemlins/k5.gif
  7. shaun
    shaun 1/2 ton status
    Apr 22, 2003
    745
    There is axle wrap and loding and unloading of the shackle when taking off. But you also net some awesome flex
  8. odoa3
    Mar 31, 2004
    1,638
    Anchorage, AK
    Thanks guys, now I just need to figure out how high I want to go.
  9. tweaker
    tweaker 1/2 ton status
    Mar 21, 2004
    263
    Modesto, CA USof Freakin A
    is there no one here who does it the old way. i hate to mention free, but it does work. sure there are dangers, but if you're confident enought to the the ORD one you can do the free way as well. just cut out the bottom and a little off the back and flip the stock shackle over and voi la, shackle flip. /forums/images/graemlins/hack.gif /forums/images/graemlins/hack.gif /forums/images/graemlins/hack.gif /forums/images/graemlins/hack.gif /forums/images/graemlins/grind.gif /forums/images/graemlins/grind.gif /forums/images/graemlins/grind.gif
    remember this is not as strong as the ORD kit is, but there are ways of strengthining it by welding a top support brace and or reinforcing plate. plus remember since it wasn't engineered to do this stock you may need to add in a degree shim to smooth out any vibrations. /forums/images/graemlins/whistling.gif
    but what do I know, two and a half trucks fliped and counting. and only the half had the ORD kit, which I took off due to new rear spring pack being un-settled. atlas 10" spring pack what ya gonna do? add in a block to cover the other 4"(I was planning on keeping the flip kit) and go home knowing the back end is 14" above stock. /forums/images/graemlins/waytogo.gif
  10. tRustyK5
    Jul 23, 2000
    36,166
    1,363
    E-town baby!
    like this?
    Rene
  11. tweaker
    Mar 21, 2004
    263
    if only i had done it like that, the longer springs off of my 89 k1500 would be way better. but alas i must sell them with the lift kit and save some poor sap the trouble of doing a add-a-leaf.
    nicely done though /forums/images/graemlins/peace.gif
