What do you guys do to remove frame rivets?
Discussion in 'The Garage' started by Jefferson-Mo, Apr 12, 2007.
  1. Jefferson-Mo
    Jefferson-Mo 1/2 ton status
    Jun 18, 2006
    141
    San Diego858, CA
    What's the best way to remove the rivets that hold crossmembers and body mounts?
    without damaging the frame..............
    Cutoff wheel? Drill? Grind? Torch?
    I'm gonna need to remove abot 20 or so and I'm lookin for the easy way out
  2. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    I'v always just used a 4.5" grinder and a center punch.
  3. bbck5on37s
    bbck5on37s 1/2 ton status
    Jan 3, 2007
    543
    Denver Colorado
    TORCH!!!!:weld:
  4. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    same here, for the ones i can't reach with the grinder, i use the torch.
  5. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Yep. Grind off the heads and pop them out.
  6. RockinChevy
    RockinChevy 1/2 ton status GMOTM Winner
    May 9, 2005
    2,313
    Chandler, AZ
    Use an electric 4.5" grinder. I used the air die grinder but it was wayyy too slow so the electric one was much quicker.
  7. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    I always used a small drill bit (1/8) in the very middle of the head about a half inch deep, and then hit it with a 1/2 drill bit till the head comes off. Hit it with the punch and out it comes. Takes me about a minute per rivet.
  8. MTChevy
    MTChevy 3/4 ton status Premium Member
    May 6, 2005
    7,141
    78
    Great Falls, MT
    if you got a lot to do, use a torch... it saved me i can tell you that... just gotta be very very careful
  9. lar300mag
    lar300mag 1/2 ton status
    Mar 17, 2006
    258
    TEXAS
    When me and a buddy was working on my truck, he used a cold chisel and a BFH. didn't take him long either, intill he hit his hand and broke it. Then we used a torch
  10. stevos67k20
    stevos67k20 1/2 ton status
    Sep 29, 2005
    140
    Somis
    LOL. does anyone have a pic of how they used a torch? i have a torch and alot of rivets to take off and i dont want a hole in my frame. do you just hold the torch flush to the frame? its seems so risky...
  11. Snowman1000
    Snowman1000 1/2 ton status
    Jan 28, 2007
    518
    Freeland Michigan
    heat the head of the rivet then on a low angle with a small burst of oxygen cut away the head of the rivet until you get down to the frame Very easy just watch out for fuel lines and anything else
  12. muddermilitia
    muddermilitia ThatTrazerGuy GMOTM Winner
    Nov 10, 2005
    5,742
    76
    NE Illinois
    this is how its done! the best way hands down, and no damage to the frame
  13. nova
    nova 1/2 ton status
    Mar 9, 2003
    285
    Laporte, IN
    Air hammer and a good chisel!! I have done many rivets with this method with no problems. Its way fast with no frame damage.
  14. blasphemous
    blasphemous 1/2 ton status
    Jan 11, 2007
    457
    Louisville, KY
    I've got the hardware, but what do you classify as a "good" chisel? Sources for that?
  15. ramjet gmc
    ramjet gmc CK5 Staff Staff Member Moderator GMOTM Winner
    Dec 19, 2001
    3,370
    Milltown NJ 08850 NJ sucks
    grinder and punch and for the ones i can not get with a grinder a drill and punch i do not have a torch
  16. lar300mag
    Mar 17, 2006
    258
    TEXAS
    lay the torch on its side and "wash" away the rivet head, little at a time. It can be a risky, but for a no risk way, use an angle grinder, air chisel or cold chisel. You can also drill out the heads, it was mentioned in an earlier post. One of the things I have learned is to take your time, if you rush things, something always messes up, it does to me.
  17. bear76
    bear76 1/2 ton status
    Oct 16, 2005
    1,065
    here
    Drilling, IMO, is the easiest.
  18. rdn2blazer
    rdn2blazer 1 ton status Premium Member
    Jun 9, 2004
    16,487
    1,192
    So Cal.
    I just look at each rivet with a scowl and point at them with one hand and a clinched fist with the other. they pop out with fear and jump right into my trash can, works everytime. :D :haha:
  19. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    same method for me. I use a flap wheel on the grinder so that it doesn't cut into the frame or bracket.
  20. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Just don't be around when does that,all your fillings will fall out.
    Chuck Norris doesn't hang-out in So Cal either.:rotfl:
