What do you guys say about this???
Discussion in 'The Garage' started by wild-will, Sep 18, 2003.
  1. wild-will
    wild-will 1/2 ton status
    Aug 21, 2003
    185
    Oak town WA
    Awhile ago i posted stuff about my truck smoking then it stoped and now its back again. Ok when i floor it the oil pressure goes up to 60 and white smoke pours out. I cant think straight i checked everything i know
  2. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    are you adding a lot of oil lately? coolant? could be bad valve guides, bad rings, blown head gasket................
  3. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    Are you sure its white and not blue?
    If so, sounds like you have a bad head gasket or a cracked head. White is usually water turning to steam. Check your radiator and see if its full. Also, remove your oil filler cap and see if theres a milky film there. Also, put your hand close to the exhaust (well after its warmed up) and see if theres moisture. If you run anti-freeze usually a sweet smell also.
    If its blue or white-blue, its oil
  4. wild-will
    Aug 21, 2003
    185
    Oak town WA
    the smoke only comes out of the left exaust port
  5. mudjunkie 82
    Dec 27, 2002
    11,449
    Cleveland Ohio
    did you do a compression test? cooling system pressure check?
  6. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    If white smoke is pouring out then you have a blown head gaske or a cracked head. I wouldn't be surprised if you get a little hesitation too, that happens sometimes too with a blown head gasket.
  7. wild-will
    Aug 21, 2003
    185
    Oak town WA
  8. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    looks kind of blue to me. Done a compression test?
  9. wild-will
    Aug 21, 2003
    185
    Oak town WA
    nope how do i go about doin that?
  10. mudjunkie 82
    Dec 27, 2002
    11,449
    Cleveland Ohio
    nice looking rig....................
  11. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    with a compression checker, don't have one myself or really know where to get one so I'm not being helpful right now.
  12. 88Silverado
    Mar 13, 2003
    2,664
    Kinda looks bluish to me too.
    If your lucky, valve guides.
    Should blow smoke when first started after sitting for 30min or more. Otherwise its rings. Do a compression check.
    But verify if its white or bluish.
    Either way, looks like your going to be at least pulling the heads /forums/images/graemlins/tongue.gif
  13. mudjunkie 82
    Dec 27, 2002
    11,449
    Cleveland Ohio
    dis- able the ignition take a plug out of the cylinder, hook up the comp.checker (screws into the plug hole)turn it over acouple of times and observe the pressure.do all four cylinders on that side and look for an pretty even pressure readings.if you have two side by side that are low the head gasket could be blown between those two. if one is low it could be blown into the water side of the motor.......
  14. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    I was thinking more worn rings so its oil, it kind of looks blue to me, I can't tell.
  15. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    454 = valve guildes. Every 454 I've had, has need valve guides at one time or another. Sounds like yours is just starting to get there.
  16. mudjunkie 82
    Dec 27, 2002
    11,449
    Cleveland Ohio
    You never did answer, does it use a lot of oil??????????
  17. wild-will
    Aug 21, 2003
    185
    Oak town WA
    No not to my recolection ive checked it after ive driven it and its almost above
  18. mudjunkie 82
    Dec 27, 2002
    11,449
    Cleveland Ohio
    how about coolant
  19. wild-will
    Aug 21, 2003
    185
    Oak town WA
    It's kinda low but i cant say for sure cause i was messin with my water neck and alot of coolant spilled out. Iam probably gonna do the comp check then pull the heads
  20. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    it could also be running very rich /forums/images/graemlins/eek.gif
