What do you guys think so far?
Discussion in 'The Garage' started by mikey_d05, Apr 19, 2006.
  1. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Modeled my K5's frame pretty closely in Solidworks and came up with this. Yes, I know it's only half of a vehicle, easier to do half and then mirror it. The axles are there too, just hidden at the moment. The front and rear of the frame are going to get cut off, just haven't done it in the model yet. Wheelbase is at 104". The way it sits in the pic it's at about 6'8" tall. Going to strip my truck over the summer and get started on a buggy/truggy. My body is falling apart from rust and trail torture. I'll probably be out for a year to two but I'll have something I can wheel for a long, long time when I'm done.
  2. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    nice work mikey
  3. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    looks good i realy like the those tires.
    j/k looks good
  4. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Haha, I really didn't want to take the time to fully model a bogger. It's doable but a waste for this IMHO. They're 39.5" tall and that's all I really care about. :p:
  5. boz42
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    i figured that i just wanted to give u a hard time. your design looks pretty good to me.
  6. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    You've got a killer cage going yourself, anywhere that looks like it'll need bracing at the moment? The floor and firewall obviously aren't done but I'm looking for structural input at the moment and your pics definitely make it look like you know how to build a cage.
  7. boz42
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    thank you, imho i think the only thing holding your design back is the stock frame, i know it is easier to build off of something that is already there, but that is the only thing holding u back. if u are dead set on keeping it that is alright & u can still make a killer rig.
    are u going to use the stock floor pan & firewall??
    i would consider pushing the engine back as far as u can & still keep a decent length d-shaft(maybe not that far but at least a few inches). the body is gone so cut the floor pan in two under the seats & take about 6" out of it & weld it back together. wieght dist. is were it is at. i moved my engine back as far as possible. also lowered it several inches in the frame. if u are going to run that bar down the center of the "A" post i would put an upside down "V" under it & tie into the top of the frame rails. i would als run a bar shoulder high parallel to the ground behind the seats from were the door bars tie to the "B" post to keep the "B" post from coming in in a hard side impact.( like the dash bar, but behind the seats)
  8. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    C'mon guys, there's gotta be more than one person with some constructive ideas. Here it is all mirrored and tubed out:
  9. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Good luck getting it that short and low with leafs.
    Other then that it looks like a cool design.
  10. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    i like it, how hard was that program to learn?
  11. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    That looks very nice. I bet when you have your engineering degree you will be able to design all kinds of cool truck innovations :bow:
  12. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    85 - The rear won't be on leaves, the front will have to have some work done to it. Maybe 44044's and a very untraditional mounting setup.
    Branndon - If you're computer savvy and have a little background, not hard. SW is $$$ though so if you don't have a friend of a friend you can get the educational edition (like $120 IIRC) but it stops working two years from the date you register it.
  13. jekbrown
    May 19, 2001
    45,030
    366
    Vancouver, WA, USA
    I'd run a tube along the floor between the b-hoop ends... and then run tube from that up to the bottom of the "windshield A-frame". Add some beef... and you need a center console anyway, right? :thumb:
    also, are you keeping the back end of the frame? looks kinda weird poking out back there...
    j
  14. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    I'm going wheeling this weekend (the pumpkin's last trail ride, I can smell the carnage) but I'll put more detail into it and implement some of the suggestions early next week.
    Jek - Gawd no. SW crashed on me and won't let me hack off the rear of the frame now like I want to. I'll do a little reworking of the model and try to get it out of there.
  15. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    what no memorial day run now...I guess ill have to get the hiking boots out lol
    Looks good mikey, I think I would rework the door area bars are bit I think a hard slam to the middle would bust that all up if its 4 bars like it looks. I think one angle bar from top back to bottom front making an isoceles triangle would work better then a 4 way tie in. Or maybe im just looking at that wrong.
  16. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Alright, set the drivetrain in there, made some floor bars, console/dash, braces, etc. I didn't run a tube from the top windshield bar to the floor because I can't find any pictures of buggies that have them so I don't think it'll fold in as easy as everyone seems to suggest. If anyone wants the SW file, let me know and I'll do my best. It's over 10 mb so I'll need an alternate way to send it since hotmail limits you to 10 mb.
  17. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    www.yousendit.com the link lasts for a week. you dont have to enter an email address, just get the link and post it here
  18. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Thanks for the link Branndon, can always count on you to come up with something like that.
    Does that mean you want it?
  19. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    sure, i haven't tried the program yet, but I learn best by opening someone elses work and tearing into it, and changing it
  20. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    i guess there isnt that much room at the front for a radiator and winch. hmmm.
    looking good.
