What do you guy's use to seal your headers with? (Gasket)
Discussion in 'The Garage' started by reddog64, Dec 10, 2002.
  1. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    What do you guy\'s use to seal your headers with? (Gasket)
    I am tired of my headers leaking...
    I tried the copper ones... 35 bucks later they still blow around the mating surface on the block and header flange...
    Tried the cheap paper ones, same thing....
    What gives...
    Anyone try the aluminum ones?
    There headman headers...
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    Re: What do you guy\'s use to seal your headers with? (Gasket)
    <font color="green"> I have Heddman's, used the paper ones they came with and they've been sealed for 4 years. I'd pull the headers and make sure the flange isn't warped before anything else. </font color>
  3. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    I heard from someone to buy 2 sets of regular exhaust manifold gaskets, and double them up. I've done it on two motors so far, and they never leaked.
  4. reddog64
    Nov 9, 2000
    3,325
    hmmm... do they make differetn (round and oblong) header gaskets?
    I think I used oblong ones....
  5. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    Forget all that stuff and take a sawsall and cut the flanges. For example on the even bank (2-4-6-8) cut the flange between #2 and #4 tube and then cut between #6 and #8 tube. Now you don't have to worry about the flange warping cause it can't /forums/images/graemlins/thumb.gif. Just one simple slice will do the job.
  6. MEPR
    MEPR 1/2 ton status
    Oct 21, 2002
    1,546
    McChord AFB
    try filliing bothe surfaces and making shure they are clean and smooth.
  7. Suffergauge
    Suffergauge 1/2 ton status
    Aug 1, 2002
    153
    Olympia, Wa.
    I use the stock gaskets. You can put in all your header bolts then slide in the gasket. They work just fine. If you are talking about the collector, mine leak bad, but I heard this deal called header hush works killer.
  8. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    I used the aluminum ones on the 406, they worked great..........and aluminum dead soft ones on the collector with header hush flanges............finally had no leaks. Definitely the biggest pain in the rear with headers. Almost not worth having them............. /forums/images/graemlins/frown.gif
  9. tRustyK5
    Jul 23, 2000
    36,172
    1,381
    E-town baby!
    I've always used the stock ehaust manifold gaskets too...never had a leak up top. Dead soft AL collector gaskets with lock nuts at the collector.
    Rene
  10. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    A trick I learned for headers on a SBC is too cut a small chunck out of the flang between 1 and 3 aswell as 4 and 7 on the left . For the right 2 and 4 , 6 and 8. It lets everything flex and seal better. I usely use Mr. Gasket Ultraseal.
  11. boots
    boots 1/2 ton status
    Nov 3, 2002
    183
    Foothills of CA (Mariposa)
    Re: What do you guy\'s use to seal your headers with? (Gasket) call me stupi
    on my '73 I'm hanging dynomax(?) headers I got new from a buddy. At the collector to tailpipe (botom of headers) I was told to use the lil paper gasket that Came with the tailpipe half of the connection. Aint no way in he!! that seals that connection, they don't even make contact. SHould there be a doughnut in that connection also? SOmeone please splain to me and try not to make me feel to stupid. Was considering grinding the collector down but then there would be noting to stop the 3 hole flange from sliding off, also been tempted to just weld em up and let it go. While on the subject of headers the one on my passenger side hits one of the bolts on the leaf spring, try as I may cant seem to get everything to twist right to clear it, everything seems to line up and bolt up well except for the t-case adapter not pulling down to the crossmember. etc etc etc. Hopefully this will all be worth the headaches, wish I hadn't rolled my '75
  12. jcg
    jcg 1/2 ton status
    Mar 19, 2000
    660
    Rochester, NY
    Do you need new engine mounts? I noticed my drivers side header had been hitting the spring clamp when the tire stuffs up. My engine mounts were totally shot and the engine had twisted in the frame quite a bit. Dropped some new poly mounts in and everything clears again.
  13. 73K5Kid
    73K5Kid 1/2 ton status
    Sep 24, 2002
    583
    chandler az
    If there leaking from the collector, I recommened cutting the collector off and welding a pipe to it. /forums/images/graemlins/thumb.gif That's what I did. I was going to get the Headerhush but I did not want to ever have to deal with leaking collectors. /forums/images/graemlins/angryfire.gif
  14. milspecjimmy
    milspecjimmy 1/2 ton status
    Aug 28, 2002
    901
    raymond, maine
    i use percy's dead soft aluminum collector gaskets. they work great, just make sure the flanges are flat.
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif
  15. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    I'll second the percy's dead soft aluminum collector, and also give a nod to their header flange gaskets.
  16. Emmettology 101
    May 9, 2000
    8,126
    FL
    I'll 3rd the Percy's aluminum gaskets! They have been on my truck for about 2 years with no leaks!
  17. Flexy K20
    Flexy K20 1/2 ton status
    Oct 22, 2002
    398
    Bay Area, CA
    I have been having the same problem, and I also have Heddmen Headers. I am pretty sure that it's leaking at
    the collector but I have only tried the standard gaskets. What are these Percy gaskets and where can I find
    them? Thanks -Flexy
  18. Emmettology 101
    May 9, 2000
    8,126
    FL
    Check out Summit, I know they sell them.. /forums/images/graemlins/smile.gif
    They are made out of soft aluminum and are supposed to seal better.
  19. milspecjimmy
    Aug 28, 2002
    901
    raymond, maine
    i get em at VIP and have seen them at pep boys. they run between 14 and 19 bucks, and come with new bolts, and its well worth it
  20. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    I'll throw in another vote for using the stock gaskets. I have used them for years and they work pretty darn good. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/burb.gif
