What do you have left b-4 the badlands trip?
Discussion in 'Midwest Region' started by BamBamblazer, May 15, 2004.
  1. BamBamblazer
    BamBamblazer 1/2 ton status
    Jun 24, 2002
    486
    McCordsville, Indiana
    So what do you have left to do to the rig before it is ready for the badlands trip, which is less than a week away. /forums/images/graemlins/eek.gif /forums/images/graemlins/thumb.gif
    1.Bleed brakes more (cant get a good pedal) /forums/images/graemlins/angryfire.gif
    2.Front driveshaft u-joints done
    3.Lube in the front and rear diffs done
    4.seat belts /forums/images/graemlins/yikes.gif done
    5.finish trimmin done
    6.add bars to cage done
    7.install recovery points
    Most of my stuff isn't major, but if the rain doesnt stop its going to be a wet wrenchin day. /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/dunno.gif
  2. K30CJ
    K30CJ 1/2 ton status
    May 16, 2003
    429
    IN
    I've already fixed my junk from the last trip's breakage. Just a matter of loading it up and heading south. /forums/images/graemlins/thumb.gif
    Edit: Just remembered I have to clean out the camper. Been sitting all winter. /forums/images/graemlins/frown.gif And I might finish the twin stick if I have time...
  3. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    Well I dont think I'm going unless its just to run around and take pics. (and swap 14bolts with Justin /forums/images/graemlins/waytogo.gif)
    My bumpers are done, I have to bolt on the rear bumper, install the gas tank, finish cutting and plumbing the lines, change the oil and filter, add gas try to start it.
    I need to get my new core support in and front bushings put in, tighten down all the body mounts, put my inner wheel wells back in for now so I can mount my battery and radiator overfill jug back in place....
    THEN, I need to figure out some way to start my cage so I can mount my buckets (Monday I might run over and check out the new scrap pile at the local steel place).
    Then the truck probley needs a tune up, tranny filter/fluid change, and it seems last winter I had a ujoint in the front driverside axle shaft popping /forums/images/graemlins/dunno.gif
    I'm going to pull the mini-spool from the 5.13 front axle and try it in the rear 10bolt thats under the truck /forums/images/graemlins/thinking.gif
    /forums/images/graemlins/smirk.gif
    I SHOULD be ready for the June 12th 4wheel parts day though /forums/images/graemlins/whistling.gif
    5/15 PM - gas tank is in and lines are connected, Front bumper is mounted /forums/images/graemlins/waytogo.gif
  4. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    /forums/images/graemlins/rolleyes.gif Just get it good enough to function and GO, weenie. /forums/images/graemlins/tongue.gif /forums/images/graemlins/deal.gif
    As far as my rig goes, I still need to lift it /forums/images/graemlins/doah.gif and install the new driver's door, and soft top if possible.
  5. BamBamblazer
    Jun 24, 2002
    486
    So Jon should i take it you WILL be there no matter what? /forums/images/graemlins/ears.gif /forums/images/graemlins/deal.gif
  6. 75-K5
    Apr 28, 2002
    5,353
    Anderson, Indiana
    Yer darn right. Even if I have to drive the K5 with a welded rear (having trouble finding a tow rig), I'll be there regardless! /forums/images/graemlins/peace.gif
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I have to get my bumpers and winch installed.
  8. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    All I have to do is put a belt on my tow rig and I'm ready!!! /forums/images/graemlins/peace.gif
    Does Badlands look for FULL DOORS and Emergency Brakes????
    I haven't been to Badlands...
    Do they have a tough safety check???? /forums/images/graemlins/dunno.gif
  9. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    NOPE, several guys ran last time with no doors. As long as it has belts I think its ok.
  10. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    Cool...
    I just noticed on the Badland web site...
    Roll bar protection required!!!
    Does that mean Full cage???
  11. BamBamblazer
    Jun 24, 2002
    486
    My wife is going to drive our k5 over there and its welded too so i say come awn we will just slide on over there. /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
  12. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    everytime I've been to the badlands, they have never checked for belt's or cage or anything. It may seem like they are strict but all you really need to do is keep your speed down in the parking lot. Other than that it's not bad. /forums/images/graemlins/waytogo.gif
    NITRO
  13. justinf
    justinf 1/2 ton status
    Sep 23, 2003
    684
    Tuscola, Illinois
    I still need to install the new wiring harness. Should have it done Monday or Tuesday night. It sucks trying to remodel the house and work on the jeep. /forums/images/graemlins/yikes.gif
  14. K30CJ
    May 16, 2003
    429
    IN
    Cool...
    I think what Troy wants is for you to have a roll cage if you don't at least have a factory metal roof. Looks like you have one, so you should be OK./forums/images/graemlins/waytogo.gif Doors are definitely optional.
    A couple more things to mention: You'll need to either bring a flag, or you can purchase one there. No alcohol in the park - they will check. Don't be late getting out of the park by closing time. Not trying to be a prick, just letting you know in advance to save you some grief. /forums/images/graemlins/grin.gif
  15. K30CJ
    May 16, 2003
    429
    IN
    You just have to get your priorities in order:
    1. Work (to make money for wheelin').
    2. Wheelin'
    3. Everything else, which would include remodeling.
    Problem solved. /forums/images/graemlins/rotfl.gif
  16. K5DRAGER
    K5DRAGER 1/2 ton status
    Jul 27, 2001
    1,164
    Momence, IL
    Hey John, you wouldn't have an extra flag I could use do ya? I just remembered that mine finally gave in.
  17. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    Here's the email I just sent dan...
    And btw, thanks for the reminder on the flag. I'll get a bicycle flag ...those ones at badlands are friggin $$$$$$$$$ /forums/images/graemlins/yikes.gif /forums/images/graemlins/yikes.gif /forums/images/graemlins/yikes.gif
    Changed out my fluids last night /forums/images/graemlins/grin.gif:
    tranny fluid was brown
    transfercase fluid was black black with the consistancy of 10W 40
    engine oil was low
    rear diff looked good, but I got some shavings out of it again
    front diff was low, but looked good with the fingertip test. I put my new cover on 6 months ago. Did not pull it back off.
    Got my K&N recharged and back on there.
    Front driveshaft has some play in slip yoke, but I should be ok.
    Other Projects to complete this week:
    Change out passenger door regulator
    Change radiator fluid overflow tank
    New rear brake lines
    Bolt down front bumper....do you have any of those chrome bumper bolts?
    Get a flat fixed in one tire
    Modify the front stabilizer mount
    Cut out tranny tunnel for shifter to work
    My plans for this week:
    Monday: Fill Oxygen
    Install Drivers trailer fender
    Install Fender braces
    Change passenger side regulator
    Tuesday: Pick up trailer
    Drop trailer off at Dan's house
    Help Dan with all his projects
    Install new inner fender skins
    Wednesday: Jaycees Meeting
    Change oil in Prism
    Thursday: Pack for Trip
    Install new brake lines
    Friday: May take day off depending on how the rest goes.
  18. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    Cool...
    Thanks... /forums/images/graemlins/thumb.gif
    I'm NOT much of a Beer drinker...
    so beer in my cooler won't be an issue.. /forums/images/graemlins/thinking.gif
    I sounds like I need to stop at K-mart for a flag though... /forums/images/graemlins/peace.gif
  19. justinf
    Sep 23, 2003
    684
    Tuscola, Illinois
    If he doesn't have one, I might. I'll look tonight and let you know.
  20. K30CJ
    May 16, 2003
    429
    IN
    I think I have an extra. I'll drop it off with the trailer and skinnies.
