what do you keep in your K5
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by James90, Jun 14, 2000.
  1. James90
    James90 1/2 ton status
    May 18, 2000
    986
    Rocky Mount NC
    I keep all kinds of stuff in my blazer and in school they picked on me for it till I had to pull them out of the mud here is a list
    30' of chain
    30' strip
    2 shackels
    full tool set
    shovel
    pic ax
    ax
    10lb sleg hammer
    3lb sleg hammer
    bolt cutters
    150' of repelling rope
    100' of par cord
    6 D cell mag light
    road flars
    fix a flat 2 cans
    large first aid kit
    WD40
    fire exstinger
    food and a cell phone just in case
    what do yuo guy carry and I need eney thing else
    James
    [​IMG]Go prepared
    </font color=red>90 k5 soon to be big, bad, and mean
  2. CrazeeBush
    CrazeeBush 1/2 ton status
    Apr 17, 2000
    464
    Middle Tennessee
    what? no spare tire? hehe I carry around 2 JL 12's, a 300 watt amp, WD40,jumper cables, a four way, a jack, a bunch of empty bottles, a tire guage, a mini maglite, a big maglite, 1 qt of oil, 1 qt of tranny fluid, some rags, misc screws/bolts/nuts, and a bunch of trash. oh yah, full socket set.
    -JoSH
    crazeebush@aol.com
    http://josh.coloradok5.com
  3. Hayduke
    Hayduke 1/2 ton status
    May 9, 2000
    271
    NE Columbus, Ohio
    tools, lights, oil, chains, jack, spair....
    and my .357 watching over it all.
    HAYDUKE
  4. James90
    May 18, 2000
    986
    Rocky Mount NC
    I forgot about the normal stuff I carry a spar and my jack and tire cangeing tools are under my hood and I keep aboltel of oil and aintfreze
    and I want to get a high lift jack
    oh and my CB and my alpine
    [​IMG]Go prepared
  5. rem7600
    rem7600 1/2 ton status
    Apr 16, 2000
    125
    Coeur d\'Alene, Idaho
    You pegged it with the Hi-Lift.. Poor
    mans winch... Where I grew up, with a chain
    saw and a hi-lift there are few things that
    can't be overcome with a couple hours time.
    <font color=purple>REM7600 - '89 Jimmy</font color=purple>
  6. CK5
    May 19, 1999
    21,622
    701
    CO
    This will sound stupid but carry what every you don't want to break. If you dont want to break an axle shaft than carry an extra one, you will then break something that you left in your garage. This is how it works in my world. [​IMG]
    Steve
  7. CrazeeBush
    Apr 17, 2000
    464
    Middle Tennessee
  8. CK5
    May 19, 1999
    21,622
    701
    CO
    Hell ya, I always carry an extra driver with me. [​IMG][​IMG]
    Steve
  9. Grim-Reaper
    7,385
    Atlanta
    Hmmmm Stuff in the 75.
    25ft of chain
    10ft of bigger chain
    varius hooks and bolts to use with chain....never have had to use the chain btw LOL
    30ftx2in recovery strap
    20ftx2in towstrap (can be used as a tree saver ect.)
    48 inch HiLift
    Heavy Duty 4 gage jumper cables
    5 7014 welding rods and a welding lens
    2 pairs of work gloves
    Spare belts
    5 Gal Jerry of fuel
    6 Gal Of water
    1 gal of Antifreeze
    5 quarts of oil
    2 quarts of Gear oil
    varius lengths and diam of hoses and a radiator hose splice kit
    2 quarts of ATF
    WD-40
    Enough axle grease to repack one set of wheel bearings
    Line Dry
    2 cans of Brake clean, 1 of Carb cleaner.
    oil storred in a large amo box that in a pinch I can use to catch drain oil.
    spare outer D44 stub
    Spare 12bolt axle shaft
    Axe, shovel (required by BLM and FS btw)
    Extinguisher
    3 spare valve stem's (use to have 5 but have had too use two)
    4 spare studs and lugs (lugs are used to hold on spare)
    veritable pletera of bungie cords, ratchet straps and hold down straps.
    6 clevis's
    Full set of tools including 3/8's and 1/2 inch metric and SAE 6 point impacts and breaker bar.
    Spare wire in various sizes and lengths
    Spare set of ball joints
    2 spares of every u-joint on the truck
    4 ton Come Along
    chunk of 2 x 12 to use as a base for HiLift in soft soil.
    Bitch box (this is for the lady, when the need arrises. and She starts to bitch "when are we going to be off the trail?" small ammo box with Toilet paper and garbage bags)
    4 way and spare tire.
    Duck Tape (brand name for real)
    Blanket, Tarp
    Parts box
    Joint press.
    4 Cell Mag
    12v 100watt spot
    First aid kit with Snake bite kit added and first responder gear
    Spare alternator (one on the truck is making noise)
    spare fuel pump
    old set of plugs
    Leatherman
    Drag link and Tie rod soon to be strapped under it.
    pair of boots for mud
    2 pair of dry socks stored in the B box.
    110lb German Sheppard security system.
    NO WONDER THE PIG WEIGHS SO MUCH!
    Diging it in the dirt with my K5's
    Grim-Reaper
    http://grimsk5s.coloradok5.com/
  10. CK5
    May 19, 1999
    21,622
    701
    CO
    What, no camera, cheese puffs?
    steve
  11. Grim-Reaper
    7,385
    Atlanta
    Wife carries the camera in her purse and I hate Cheeze puffs. I carry Tostidos and salsa :) Depdog can vouch for that from the Tellico trip hahaha. Going camping this weekend...you want me to add that to the list?
    And your right...if you carry a spare you never break....so far I have never broke my truck but that D44 stub has been passed around a good bit but never installed. Seems everybody who has ever needed it also needed the inner that I don't have.
    My bud still takes the cake. He had a ARB come apart in his 76 K5 and one of the ring bolts got pushed through the diff cover on his 12bolt. He had a spare cover with him!
    Want a picture?
    Grim-Reaper
  12. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    WHERE IN THE HELL DO YOU ALL KEEP THAT MUCH STUFF????? I CARRY "LUCK" MOST OF THE TIME. MAYBE A SPARE AND A JACK, MAYBE A FEW TOOLS. COURSE HERE IN AZ WE DON"T HAVE MUCH OF THAT BROWN STICKY STUFF OR EVEN THAT WHITE STUFF.
  13. chevidog
    chevidog Registered Member
    May 27, 2000
    42
    Western South Dakota
    Tops off and I've got a fourteen foot canoe in the back right now. Rigged up so nice it almost looks stock. Normally carry whatever I think I'll need for that particlular weekend. Always included is the german shepard security system, now only about 45 lbs (born on the millenium-sweet). Her name is Chevi! Oh Yeah!
  14. dumbfounded
    dumbfounded 1/2 ton status
    May 20, 2000
    176
    Castalia, NC
    hhhmmmm
    12 pack
    plenty of ice
    my dog
    gal of H2O
    misc. spare parts
    fix a flat
    doritos
    couple qts of fluid
    DUCK tape "quack quack"
    rope
    good tunes
    portable batt. starter
    and a smile on my face......
    Oh yeah. my old lady if she's being good....
    Wasn't me.............
  15. dumbfounded
    May 20, 2000
    176
    Castalia, NC
    OH yeah. My AAA card and a cell phone. "just in case"
  16. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    I figure Grim's a damn good guy to have with ya on a trailride...
    [​IMG][​IMG]
    Durant, Ok
    '79 Blazer in progress
  17. behemoth
    behemoth 1/2 ton status
    May 16, 2000
    1,833
    Northwest Florida
    In the '78 Cheyenne:
    Various as mentioned above.
    12 pack (minimum) Busch.
    S&W 5903 w/spare clip.
    Camping stuff as required for particular trip (i.e. pull right off road or go where there is no road at all).
    If hunting - all necessary for that particular game.
    behemoth K5
  18. 1TUFF89
    1TUFF89 1/2 ton status
    Apr 6, 2000
    109
    West Point, Virginia
    As many girls as possible. Just kidding. Think about it though - how many girls would actually fit inside a K5 Blazer - a lot!! Anyway, I keep a 20 foot chain, a tow strap with a 6,000 lb. limit, jumper cables, tools, my California amp, and my two 15" subwoofers, as well as my spare tire in the back. Can't go wrong with a chain and a set of tools!
    Chevy's RULE!
  19. AZK5
    AZK5 1/2 ton status
    Feb 22, 2000
    448
    Chandler, AZ
    I carry the usual stuff mentioned plus change of oil, filter and starter fluid (when I suck up river), 12 bolt axle, full size shovel, fuel pump and filter, lot's of wire and terminals, Mossberg 12 gage with 20" barrel.
    CB
  20. Depdog
    Depdog 1/2 ton status Author
    1,657
    Georgia
    O.k. well you asked, all this stuff I carry when I wheel, not much of it comes out when I dont, except the food and camping gear basically, oh and the GLOCK, it goes back to work with me!
    GLOCK 23,or 22, or 27 depends
    Spare Clip for said Glock 15 rd.
    Garmin IIIplus G.p.s.
    Cobra c.b.
    Motorolla Family channel radios 2 with headset(for spotting)
    Motorolla Star Tach Cell Phone
    Motorolla Pager
    12 Gallons of Water
    5 Gallons of Fuel (plus the 31 gallon tank)
    5 quarts motor oil and filter
    1 Gallon of Grear oil and catch can
    Funnels
    1 Gallon of Antifreeze
    Axe
    Fullsize Shovel
    60 inch High Lift
    12"x12" 3/4" thick plywood base for said jack
    25 foot of heavy duty logging chain
    8 Clevises, 4 on K-5
    2"x20' snatch strap(used lots on other people)
    4"x30' snatch strap
    Warn HS9500i on cradle
    12,000 lb Warn Snatch Block
    6' Tree saver strap
    First aid kit with lots of stuff
    Box of screws and various other small fastners
    Box of Bigger nuts and bolts
    On board Air with blower and tire chuck (no air tools YET)
    2 fire extinguishers
    U-Joints, all mine are the same except the axles
    Front driveshaft
    Rear driveshaft
    12 bolt axle shaft and bearing
    Dana 44 front axle shaft short side complete (now)
    Dana 44 long axle shaft complete
    Tie rod with ends
    Drag link with ends
    Pitman arm
    Belts for all 3 on the engine
    Radiator hose patches and clamps
    Test Light
    Various pieces of wire and elec connectors
    Full tool box of tools
    Leatherman
    Gerber Multi Tool
    Duck Tape (like Grim said, Name Brand)
    Electrical Tape
    Self bonding nylon reinforced rubber tape
    Grease gun full of grease
    Front wheel bearings and seals
    Spare set of front Hubs (Warn)
    Lug nuts and Studs
    Full Size spare tire
    Valve stems, caps, and valve cores
    Real Tire Plugging tools and plugs
    Bailing Wire
    3 Tarps of various sizes
    2 Pairs of Boots
    3 Pairs of Socks
    Tent
    Sleeping bag or bags (depends)
    Air mattress (thats what the blower is for)
    Carb. gaskets
    Fuel Pump
    Spark Plugs
    Spark Plug wires
    Fuel line and clamps
    Fuel Filter
    Jumper Cables (20 ft,can go front or rear to winch plug)
    Air Hose 50 ft.
    Spare hose and fittings for on board air
    K&N filter cleaner and oil
    Slide Hammer
    Rear Drive shaft Yoke for NP 205 tcase
    Blue R.t.v. Silicone
    2 part epoxy like J.B. Weld
    Large bottle of Super Glue
    Lots of Zip Ties
    Front Spider gears for Dana 44 (have lock right locker)
    Hand Cleaner
    Rags
    Paper Towels
    Windes Glass Cleaner
    4 Cans of Carb. Cleaner
    WD-40
    U-joint straps and bolts
    U-bolts for leaf springs
    Leaf spring center bolts
    Rear Shackles
    Stock Rubber Brake Lines
    Power Steering Fluid
    Stock Ignition module and wires (I have a Crane Ignition)
    12v light with 25 ft cord
    3d cell Mag light and spare batteries
    4 way lug wrench
    3 pairs of gloves 1 leather for winch
    Digital Camera
    Camcorder depending
    Real Camera depending
    Small Propane powered grill with 2 small tanks
    Lots of drinks and snacks, not to mention real food
    All cooking and eating utensils and condiments (not condoms)
    I am sure there are some little things that I am forgetting, depending on where I go, these things change and or get removed.
    Depdog
    <font color=blue>"Lead, Follow, or BECOME the Trail"</font color=blue>
