what do you paint axls with?
Discussion in 'The Garage' started by bryguy00b, Jul 6, 2002.
  1. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    when you paint up axls and all that and the frame do ya do it all in POR-15?
    thanx-Bryan
  2. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    94.00 Flat black spray paint. Easy touchup /forums/images/icons/wink.gif Just make sure you degrease everything very well before you paint it.
  3. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    When I did everything on PI from the frame down I prssure wased the crap outta it then used some old cheapo enamel paint I had laying around. I think it was Limco. Maybe Nason. I dont remember anymore! But it was one of them. I used almost a gallon on the frame, springs, axles, and inner fenders. I used gloss black so that clean up will be a snap. If its shiney... its smooth. If its smooth... itll clean up easy. /forums/images/icons/wink.gif
  4. jekbrown
    May 19, 2001
    45,032
    369
    Vancouver, WA, USA
    you might try appliance enamel. Its heat resistant, and some of them are epoxy based, so they are pretty tough.
    J
  5. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    cool...i just want something tough, and that would make it look better..cause who wants to look at rusty axls and springs after you have your truck all lifted!!??of course you would have new springs if you did a whole system thuogh.
    Bryan-thanx
  6. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    I used engine enamel on mine with an additional clear coat. Dirt washes right off.
  7. carolina custom
    carolina custom 1/2 ton status
    Dec 29, 2001
    161
    Mt. Pleasant SC
    Por-15 chassis cote. It a nice sattin black. /forums/images/icons/cool.gif
  8. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    did you do it a certain color or just black?
    Bryan
  9. Mike.S
    Mike.S Registered Member
    Jul 4, 2002
    30
    S.E.TN.
    I just painted my axles in preperation for installation. I sprayed the pumpkins,dif.covers,and hubs with enamel for the heat resistance like jekbrown said, and the tubs with just a cheap primer. That way, touch up on a regular basis won't be expensive. All in flat black. But doing it in gloss sounds like the way to go for the easy clean.
  10. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    yea..well, thanx for the tips guys!! /forums/images/icons/cool.gif
    Bryan-thnx
  11. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    I used Napa's Industrial Coatings black engine paint. Durable, easy to clean, and looks good too. /forums/images/icons/smile.gif
  12. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    so did ya just take them out and paint them or did you do it while you were in the process of something else? i think i would do t when im putting a lift in! /forums/images/icons/wink.gif
    thanx-Bryan
  13. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    o yea what do you use to paint it? a gun or a brush or what?
    thanx-Bryan
  14. carolina custom
    Dec 29, 2001
    161
    Mt. Pleasant SC
    The POR-15 chassis cote is a sattin or simi-gloss black that duplicates factory look. I would recomend spraying. It is UV stable(hope thats not an issue /forums/images/icons/grin.gif ) and you can apply second cotes with out using por-15's tie-cote prep.
    Marc
  15. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    sweet...any major preping to do..or do you just take the axle right out and spray the thing?
    Bryan
  16. carolina custom
    Dec 29, 2001
    161
    Mt. Pleasant SC
    yeha, paint gun. /forums/images/icons/wink.gif
  17. carolina custom
    Dec 29, 2001
    161
    Mt. Pleasant SC
    I just wire brushed my 3/4 tons under the truck and sprayed them with por-15 meatle prep(it is like ossfo) and then sprayed them with chassis cote. I am doing my 1 tons this weekend. I sand blasted them, replaced pinion seals, and breaks, and have only painted the 60 so far.
  18. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    ahh kool..do you have a sand blaster?
    Bryan
  19. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    Im sandblasting mine and then painting the axles gloss red and when i get the lift, its gonna be white prolly. so then my truck will be red white and blue. /forums/images/icons/tongue.gif
    NITRO
  20. ramjet gmc
    ramjet gmc CK5 Staff Staff Member Moderator GMOTM Winner
    Dec 19, 2001
    3,370
    Milltown NJ 08850 NJ sucks
    por-15 /forums/images/icons/grin.gif
