What do you put on the top so you can paint it?
Discussion in 'The Garage' started by google, Jul 9, 2005.
  1. google
    google 1/2 ton status
    May 19, 2005
    805
    Arizona
    My top is really porous (sp) and in need of something to fill it before I paint it. What am I supposed to use?
  2. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    i did mine with epoxy resin, i worked in a boat yard so it was handy, coated it once sanded it and went back with another coat sanded and painted after that
  3. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Multiple cans of spraypaint. At first I didn't think it would do the trick but it turned out pretty nice.
  4. k5freak44
    k5freak44 1/2 ton status
    Jun 1, 2004
    2,164
    Plano, TX
    mikey, you got any pics of how your top came out? mine is faded and i want something that will be easy to touch up
  5. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Ummm...not up close. Imagine a krylon gloss black finish with your fiberglass top's texture and you've got it. If you don't do anything to it beforehand though be prepared to put three or four full coats on it before the paint stops soaking in. I would go out and take a picture for you, but the truck is up on a trailer now so it's forkin high off the ground.
  6. google
    May 19, 2005
    805
    Arizona
    Do I need to go to a boat shop for that or maby just a checker or any paint shop??? Thanks
  7. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    I sanded mine down smooth with an electric sander then wet sanded it, primed, wet sanded again and then painted. Turned out real nice.
  8. ryoken
    Jun 13, 2003
    29,622
    1,374
    Jersey Shore
    i would just DA it down with some 80 to 180, denature it, load it with epoxy prime, sand and paint... just load the primer up and it will fill the porosity pinholes.. unless your actually seeing hairs before or after sanding i wouldn't bother with an epoxy or polyester resin...
    or ya could just scuff it and roll something on... ;)
  9. OLD DAWG
    OLD DAWG 1/2 ton status
    Jul 20, 2002
    444
    MONTROSE, COLORADO
    I gotta agree, sand followed by a good high build primer should do-er
  10. diesel4me
    Jul 24, 2003
    17,540
    930
    Massachussetts
    "Feather Fill"
    We sold some 2 part stuff called "Feather Fill"(*made by "MORTON") at the body shop supply stores I worked at--it had a hardener,the clear stuff like fiberglass resin uses...This stuff is like a thin sprayable bondo,it fills all the holes and cracks in a metal or fiberglass body and it looks like an eggshell colored coating thats very smooth when it dries..its a bear to clean out of the spray gun though..might want to use a cheap gun,or your least favorite for this chore...sanding the "bumps" off works,but most factory hardtops are on the thin side as it is..most of the tops I've seen sanded smooth cracked easily--but then,so did the bumpy ones.. :doah:
  11. resurrected_jimmy
    May 23, 2005
    2,241
    A paint shop should have it but this is one of the few things that is cheap at a boat shop, i did mine that way because we had it in 55 gallon drums so it was available.....looking at some other posts mine was showing "fibers"... bare glass, so it was time to build it back up, i am very happy with the way it turned out
  12. 88trailblazer
    88trailblazer 1/2 ton status
    Apr 11, 2004
    425
    Miami, Florida
    I used a flexible primer from the local piant shop. It's supposed to the same thing that they use for boats. It seems to have worked great so far. All you need is a pint of that stuff and it dries up quick.
