What do you RUN in your steering system..
Discussion in 'The Garage' started by 78Suburban, Sep 19, 2005.
what fluid?
  1. GM power steering fluid
    58 vote(s)
    57.4%
  2. Dextron/Mercon III atf
    43 vote(s)
    42.6%
  1. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    So what fluid do yall put in your stock power steering resevoirs.. Those of you that have converted to hydro, tell me what you used to or would run in the stock system.
  2. justinf
    justinf 1/2 ton status
    Sep 23, 2003
    684
    Tuscola, Illinois
    I picked Dexron/Mercon ATF, but I actually run Type F ATF because I believe it handles higher temps better, seems to work well with the hydraulic steering in my jeep.
  3. 81jimmyslt
    81jimmyslt 1/2 ton status
    Jun 5, 2003
    1,643
    So Lake Tahoe (Rubicon), CA
    I run power steering fluid, and don't have hydro yet either. From what I have read and know ATF is cheaper than power steering fluid, but ATF breaks down the seals faster. Also power steering fluid has higher tolerances and runs cooler (?).
  4. walla2k5
    walla2k5 1/2 ton status
    Sep 5, 2004
    2,054
    Walla Walla, WA
    Been running ATF for years no worries....
  5. diesel4me
    Jul 24, 2003
    17,577
    943
    Massachussetts
    Dextron..
    I voted Dextron ATF--I've used in it all my GM trucks power steering and plow pumps for 20+ years--never had any trouble or leaks..I suppose "real" power steering fluid is better,but I only used it if I found some free behind the seat or something! :crazy:
    But use what it says in the owners manual if you have a forigen car--Honda's and VW's power steering pumps croak in a few hours if the wrong non-factory P/S fluid is used--its like their seals melt like candle wax if anything else is substituted! :doah: .. :eek1:
  6. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    I voted PS fluid, but lately I've run Lucas Oil stop leak fluid. It leaks a lot less, but is $4 a bottle so I can't tell if I'm better off.
  7. HELLBENT DESIGNS
    HELLBENT DESIGNS 1/2 ton status
    Apr 2, 2005
    453
    bozeman mt
    plan on running atf even with the hydro steering, since i have an auto trans i can use 1 fluid for spare instead of 2 :D
  8. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    I did it
    Well, I got my mom to pick up some GM powersteering fluid on her way home today. it was like $1.29 a pint and I got 2 pints (so I would have extra)... I jacked the truck up poured in the juice........ well, I way overfilled it. so I started it up and did the steering thing. that didn't make the level go down any...
    My mom is a vet, so I borrowed a seringe and needle started sucking fluid out of the resevoir. I got the level down to 1/4" above the full cold mark and called it a day..
    I'm such a goober.. I felt like Mister bean today
  9. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    As i mentioned before, in another thread, just put in alittle brake fluid in it, if it's not a horrible leak, like just a seal, it should stop, had a few friends we did this to, and a couple of my own cars, still runnin the Burb with this in it after a year when it started leaking.
    Maybe like 1-2 cap fulls, not a lot of it, too much can be bad.
    AND, it's cheaper than that stop leak stuff, and not as thick :D
  10. captaininsano
    captaininsano 1/2 ton status
    May 4, 2004
    233
    Bay Area, CA
  11. spoolnaround
    spoolnaround 1/2 ton status
    Apr 8, 2002
    1,419
    Kingsburg Ca
    I run a manual trans, atf isnt any cheaper so I run ps fluid.
  12. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    I've always run ATF with no problems. :D
  13. Desert Yeti
    Desert Yeti 1/2 ton status
    Mar 20, 2003
    320
    Tucson, AZ
    Been running ATF in the steering in all my GM cars and trucks (all pre 1980 ones anyway) for decades with no problems.
  14. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    usually atf, just because i rather buy somthing that'll work in 2 things.
  15. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    I run GM fluid in my full hydro, ran GM fluid in my assist system before that. I've run the valvoline synthetic with good results but from the people that know more than me, when the going gets rough, the valvoline foams too much.
    The GM fluid has a lot of anti foaming additives which make it the hot stuff.
    For less demanding work, parts store ps fluid seems fine.
    I've also heard ATF's additive package is less friendly on seals than PS fluid, but experience seems to indicate that you can get pretty good life with it.
    In a pinch (on the trail) I'd run anything oily, gear oil, motor oil, whatever.
  16. sweetk30
    Nov 1, 2004
    25,549
    543
    horseheads , ny 14845
    just a fyi for ya all most new fords now call for atf fluid. but i like p/s fluid my self.
  17. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    I voted for Dextron/Mercon III ATF since that is what GM says to use in the system and it is cheaper than PS fluid. Look on the PS resevoir cap and it usually says right on it to use ATF.
  18. dyeager535
    26,981
    I voted PS fluid because I have no idea what "Dextron" is.
  19. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    PS Fluid. Why wouldn't you use it? Is there some advantage to using ATF?
  20. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    I'm running B&M trick shift ATF in my rig with hydro assist. It's pricey but I got it for free from summit when I got a trans cooler from them. Since I have a manual tranny I didn't want to waste it so it went in my power steering system (took about 2-3 quarts too!!!)
