what do you sand your axls with?
Discussion in 'The Garage' started by bryguy00b, Oct 7, 2002.
  1. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    i want to repaint my axls..what do you guys use to sand down your axls to get some of that rust and crap of them? and i live in rochester by the way...so i have the worst of it! lol...i was thinking just sanding them down best i could and spraying them with some black spray paint...
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I've used a rotary wire brush and a drill to do it before. It takes a long time, but it does a good job. Be SURE to wear eye protection!!!! Sometimes the bristles will fly out of the wire brush. I've had them stick in my arm, so I don't even want to think about what they would do to an eye. I have a full-face shield that I wear when doing stuff like that. /forums/images/graemlins/cool.gif
  3. lgk5
    lgk5 1/2 ton status
    Apr 3, 2001
    269
    slc,ut.u.s.a
    i just did mine with a wire wheel on my grinder
  4. georgiared84
    georgiared84 1/2 ton status
    Sep 5, 2002
    487
    Austell, Georgia
    I just finished off my 14 bolt junkyard special with a big wire brush. It took a while, but not nearly as long as sanding would. I was thinking about using a sandblaster, but didn't know if I'd screw up the seals, etc... I'll be cleaning them up a little more and painting them with black epoxy.
    P.S. if you do this while it's still attached to the truck, wear good eye protection. sounds like a nobrainer, but I spent a while at the doctor's getting rusted metal out of my eye a few weeks ago after using a wire wheel under the front axle.That's one of those times when you say to yourself "I knew that was going to happen, so why the h*** did I do it?"
  5. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    I had them sand blasted. Cost me $20 an axle. The guy would have done them while they were still under the truck too! /forums/images/graemlins/thumb.gif
  6. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    I used some strong paint remover before. This will soften all old grease and crud that's stuck in there.
  7. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    A 4" grinder with one of those braided wire brushes. It helps to have both the cup style and the radial style brushes. You will go through one quality cup style wire brush on a set of really rusty axles. Mine came out great though. Took maybe an hour per axle to do a really good job.
  8. nvrenuf
    Jan 7, 2002
    13,088
    252
    Mobile, Al.
    I use Easy Off oven cleaner. Let the part or axle sit in the sun and get good and warm then soaking with a generous amount of oven cleaner, after about 20 minutes spray it off and it will usually cut all the way to shining bare metal.
  9. moneypit
    moneypit 1/2 ton status
    Sep 3, 2000
    1,382
    COLORADO
    I scrape them with ROCKS! /forums/images/graemlins/thumb.gif
  10. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    Sandblaster. I borrowed a small blaster from a friend and only had to purchase the sand. The sandblaster can reach places the brushes never will.
  11. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    and there was no problem when they hit the brakes, likes, etc.when sandblasting?
    /forums/images/graemlins/ears.gif
  12. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    sandblast it, then you'll have time to do other things.
    McMaster-Carr part #31195K11 for $55.00 bucks (562)692-5911 /forums/images/graemlins/tongue.gif /forums/images/graemlins/tongue.gif
  13. RedBrute
    RedBrute 1/2 ton status
    Sep 22, 2002
    346
    Southern tier New York
    I've done 4 complete diffs, 2 front and 2 rear. Did them with a 4" angle grinder and twisted wire cup wheel and 80 grit strip type sand paper. When done all were painted with POR15. A year later no rust on the set I still have, and I too live in salty New York. I'd use a sandblaster if I had a bigger compressor.
  14. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    wow like no rust biuld up or nothin!?? easy to clean..? if thats true i might go for that...i want to try to keep my drive train pretty clean as much as i can hear...
  15. juanblzer
    juanblzer 1/2 ton status
    Sep 12, 2001
    1,614
    9
    Chandler, Arizona
    yeah, I'm with Moneypit on this one. I sanded my frame and my axles with rocks, dirt, branches, rocks, etc.
  16. 8_YOUR_H2
    Feb 20, 2000
    2,663
    Iowa
    The guy who did mine was a surgeon with the sandblaster. A real quality place will have different size tips and be able to avoid blasting things you want left alone. He was also able to blast inside the tubes (they were bare housings when I took them in).
    1 thing I would do differently, I wouldnt do inside the tubes or in the diff its self. It was TOO hard to get all of the sand out. I ended up renting a pressure washer to get it all cleaned out, but its good as new now...actually even better since it has 4.88's and a detroit!
  17. blk87K5
    blk87K5 1/2 ton status
    Dec 26, 2001
    1,290
    Lubbock, Texas
    I had mine sandblasted, then sanded them down with 80, 200, 400, and 800 grit sand paper. After that, I took them and had them chromed. /forums/images/graemlins/thumb.gif Make sure you get every piece of dirt and rust off before it goes to the chromer. /forums/images/graemlins/wink.gif Truthfully, I sand blasted them. Took longer to get the blaster hooked up than it did blast them. Then I shot them several times with primer and several more times with black paint. The only reason I bothered was my axles were about 1/2 burried in a field when I got them. Black axles look cool under a black truck when you're cruising the mall at Denver West to pick up the 12 year old hotties. "I swear officer she had a huge vocabulary for a 12 year old."
  18. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    So how do you get the top?
  19. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    that is wrong on SOOOOO many levels /forums/images/graemlins/rotfl.gif/forums/images/graemlins/eek.gif/forums/images/graemlins/rotfl.gif
  20. k5ntexas
    k5ntexas 1/2 ton status
    Oct 29, 2001
    2,517
    corpus christi, texas.
    i swear you come up with some off the wall stuff. crazy texan i swear. /forums/images/graemlins/rolleyes.gif later.
    jacob
