What do You think is the best gear lube???
Discussion in 'The Garage' started by JK5, Mar 25, 2004.
  1. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    I like to run Torco GL-6 90/140W Petroleum based gear lube
    in my d60/14bff.
    What do you run???
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I run whatever...I never keep track of what brand I use. Gear oil is gear oil to me.
    The best, without question, would be a full synthetic. Mobil 1, Amsoil, Redline, Royal Purple....
  3. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    I just use the 5 gallon buckets of Oreill'y Brand "the cheap sh!t" I change it at least every month, damn mud and water kills it quick.
  4. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    I use Penzoil (the tall yellow bottles) mainly because that's what the Wal-Mart near me carries.
  5. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    I like the cheapest crap I can find that'll pass fer gear lube. But I think Royal Purple or Redline would be the best...
  6. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    Like most have said. I use the cheapest stuff in the trail rig, since it's best to change after a deep water crossing or whatever...
    In the tow rig, I'm getting ready to put in Amsoil Series 2000...good stuff.
    On a side note, I'm going to put Redline in my 6speed...
    Boss
  7. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    The cheapest name-brand stuff I can find. Or off-brand if it says it's made by the same people as the name-brand stuff. I tend to run Valvoline semi-synthetic or the "Slick 50" gear lube. I usually stay away from house brands and the such like Coastal and Super Tech.
    If I were to run expensive stuff it'd probably be Golden Spectro or Redline.
  8. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    People who know use VALVOLINE .
  9. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    There ya go /forums/images/graemlins/waytogo.gif
    I was thinking about running the royal purple in my rig because its not suppost to mix with water. I was thinking I could suck any water out and top it off and be fine /forums/images/graemlins/whistling.gif
    could put a drain plug half way up the back of the cover, unplug it and let the top half drain out (being water). Put the plug back in and refill to the hole in the front.
    I would hate to run synthetic stuff and drain it monthly /forums/images/graemlins/yikes.gif
  10. Emmettology 101
    May 9, 2000
    8,126
    FL
    Ya, I ran elcheapo 'Zone stuff or Castrol.. Changing regularly gets expensive, so cheap it was. /forums/images/graemlins/smile.gif
  11. Wingnutt
    Wingnutt 1/2 ton status
    Feb 20, 2000
    324
    NOVA
    The best lube in the world is pure BEAVER OIL!, oh wait a minute, you said GEAR lube./forums/images/graemlins/whistling.gif Sorry I just coundn't help it, it's been a long time since we've had a beaver oil thread. /forums/images/graemlins/histerical.gif
  12. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Water is more dense than petroleum, even in crude form. Therefore, the water would be at the bottom of the diff, not the top. /forums/images/graemlins/deal.gif /forums/images/graemlins/waytogo.gif
    Clicky
  13. 89fullsiz
    89fullsiz Registered Member
    Mar 23, 2004
    96
    Portland, OR
    Don't know much on 4x4's so I'm kinda talking out my ass. But GM makes GREAT differential fluid. I only use GM fluid in my GM Cars. If you need a number for a discount dealer to get it relatively cheap let me know..... its comparable to gmpartdirect without the stupid crazy shipping charges...
    But like I said for cars\drag racing etc I right but these rigs I don't really know alot just trying to help /forums/images/graemlins/pimp1.gif
  14. Emmettology 101
    May 9, 2000
    8,126
    FL
    GM Synchromesh is good poop!
  15. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    I use synthetic...
    when I want a milkshake!!!! /forums/images/graemlins/yikes.gif
    That stuff HATES the ALL the water I play in.. /forums/images/graemlins/whistling.gif
    Have you ever tried full synthetic???
  16. Beast388
    Nov 6, 2001
    3,039
    Clinton, IA USA
    I run Castrol 80w-90 that I can pick up at Walmart for $2 a quart. As often as you change that stuff, cheap is good. /forums/images/graemlins/waytogo.gif /forums/images/graemlins/peace.gif
  17. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    For the K5 the best gear oil is the kind with the least water in it /forums/images/graemlins/tongue.gif
    In my s10 I use Mobil 1 mostly in an attempt to get better gas mileage as I could care less about wear.
  18. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    If you pass through water sometimes, how often should I change the oils?
  19. BlazerGuy
    Apr 20, 2000
    9,206
    abcde
    Everytime your in the water that's over the hubs, Or a least check it after every dunking...
  20. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Okay thanks. What will happen if I dont, will it wreck any parts?
