What do you think of an S10 tow veh?
Discussion in 'The Garage' started by 8_YOUR_H2, Aug 19, 2002.
  1. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    I am looking for a tow vehcile. I want to go as cheap as possable. The only cheap trucks are eaither so tired they wont even move with my fat but in them or S-10 pickups. I did some research and found the S10 with 4.3 V6 has a towing capacity of 6000 pounds. This is good enough to tow my blazer, what do you folks think?
    Brent
  2. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color="blue">I towed my Blazer with a 1/2 ton pickup once and it was scary. I wouldn't even think of doing it with an S10
  3. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    yeah I think an s-truck would be quite scary. IMO you need something fullsize and longbed to tow. Yes its costly but I definately don't think an s-truck is up to the task without major brake and drivetrain upgrades...
  4. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    I wouldn't try it ether.. /forums/images/icons/ooo.gif
  5. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    you've got to be kidding...
  6. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I towed my Blazer to Moab with a '98 Dodge fullsize clubcab and I didnt think much of that. I sold it and bought a 1 ton xtra cab dually. That tows just fine. I was coming over this pass on the freeway just south of Salt Lake on the inside lane when a car in front of me jammed the brakes. I was in the gravel on the outside before I had it back under control. The truck just was not heavy enough.
  7. mercercadet
    mercercadet 1/2 ton status
    Apr 19, 2002
    216
    Georgia
    I have to agree that it wouldn't really be a viable idea, I loaded down an 86 1/2 ton that had a 4.3L v6 with the drivetrain out of my k20 to go into a jeep and performance sucked royally....i wouldn't think of a trailer and an actual truck. I would think the cheapest you could go with is a half ton with a 350 and good low gears. then again i don't tow as much or as far as some here do. /forums/images/icons/smirk.gif
  8. BowtieBlazer
    Jul 15, 2001
    2,462
    if you go against the grain and go that route be sure to swap in a standard tranny...ABSOLUTE WORST CASE use engine braking and brakes to stop.
    Hey I sound like I've done that with my muncie 465 before /forums/images/icons/ooo.gif
  9. Lance
    Lance 1/2 ton status
    Mar 4, 2002
    606
    Birmingham, Alabama
    I know hauling a payload is different from towing but, when I brought home my 1-ton axles in the bed of my s-10 work truck, with the 4.3 V-6, the truck was definitely at its capacity. The front end was raised up about 4-5" (just a guess) and driving the 1-1/2 hours home was an experience to say the least. I wouldn't recommend an s-10 for anything more than a daily driver and light load hauler.
  10. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    No way. An S-10 is narrower than a Jeep Wrangler. Not the best platform for towing large, heavy loads. And the only way an S-10 will even get 6,000 lbs. up to speed is on a flat road, at sea level. /forums/images/icons/shocked.gif
  11. nvrenuf
    Jan 7, 2002
    13,081
    248
    Mobile, Al.
    My daily driver is a 87 S-10 4WD (2.8 V6), purely from a weight capacity point of view - NO WAY!!!!!
    An S-10 might be able to move 6000lbs on a flat surface but there is no way it could stop that kind of load not to mention that the tongue weight would probably put the bumper in the grass! I put a complete 454 in the bed once and mine was almost on the bump stops.
    I understand the money part but it's just not the right vehicle.
  12. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    No way!! No way!!!
    Dangerous!!!
    Ken H.
  13. 8_YOUR_H2
    Feb 20, 2000
    2,663
    Iowa
    I get the feeling its not a good idea? /forums/images/icons/confused.gif
  14. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    i had very scary time with a burban pulling my blazer. flat toeing but still towing.
    i will never flat tow unless i have no other choice.
    nor will i use a half ton to pull my blazer. i am looking for a C or K 30 crew cab dually right now.
    an a goose neck
    grant
  15. four_by_ken
    Jun 9, 2001
    3,806
    Allenton, MI
    Yeah... too short of a wheelbase... not enough weight. Ratings are too low. Not enough power. Brakes are too weak.
    Just really not a good idea.
    Ken H.
  16. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    What do you mean? Everybody thinks its a great idea! /forums/images/icons/laugh.gif
