what do you think of my new plan?
Discussion in 'The Garage' started by 87sm465np208, Oct 29, 2002.
  1. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    i got a 12 bolt 4x4 rear axle yesterday, decent shape, but........ it is the wrong ratio, but i got it for free, so im not complaining, but here is my plan, since 12 bolt 4x4 axles at junk yards are teh wrong ratio and expensive, i was thinkin of seeing if i can find a 2WD 12 bolt from a suberban or somthin, seeing if it is in alright shape and the right ratio, and gettin it. now for my question, can i slam these 6 lug 12 bolt axles with my old drums, in a 2wd 12 bolt? will the splines be the same? id really like to know, ill be forever in your debt if you help.
  2. efilnikufecin
    efilnikufecin 1/2 ton status
    Feb 27, 2002
    168
    flint,mi
    i pretty sure that would work not positive.i think you just need to replace the backing plate from your 4X4 12bolt on to the 2wd.then throw in the 6 lug axles.i believe the spline count is the same also.
  3. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    Yes the 2wd and 4wd axles are interchangeable. I have a 2wd 12 bolt in my truck with the 4wd (6 lug) axles in it. The junkyard wanted $600 for the 4wd version and I got the 2wd one for free.
  4. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    $600?!?!?! /forums/images/graemlins/ignore.gif /forums/images/graemlins/shocked.gif /forums/images/graemlins/1zhelp.gif And I thought $350 for a 10 blt was bad.
  5. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Good luck finding a 2WD 12 bolt with 3.73's...all the ones i've seen are 2.73 or 3.08
  6. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    your not in California /forums/images/graemlins/smirk.gif
  7. Blazinaire
    Mar 17, 2002
    1,262
    Santa Maria, CA
    Don't worry, I told them where to stick it and then I got the 2wd one for free, threw my 6 lug shafts in and had it regeared to 4.56... hmmm and yet still under $600, those guys think they got somethin' special.
  8. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    Yes you can do that but I would also put the 4x4 backing plates and brakes on the 2wd axle.
    My 79 K10 has a 2wd 12 bolt in it now. I just unbolted the backing plates and left them in the truck while swapping the axle. Then I didnt have to bleed the brakes when I was done /forums/images/graemlins/thumb.gif
  9. 87sm465np208
    Aug 28, 2002
    1,114
    illinois
    pretty slick, i might do that, i have a 4x4 12 bolt, with 3.24's and i need 3.08 /forums/images/graemlins/mad.gif, i wonder if i could goto the junkyard find an axle and bring one of my axle shafts in there to see if it fits.
  10. 87sm465np208
    Aug 28, 2002
    1,114
    illinois
    turns out the 2wd 12 bolt is 125 at one junk yard 175 at another, i have the axles, and backing plates if needed, 12 in. the ones on my 10 bolt are 12 in, i dont get it., could i use the drums off the 10 bolt on a 12 bolt?
  11. kennyw
    Jun 9, 2002
    13,224
    94
    From what I have heard you can use the brakes off the 10 bolt on a 12 bolt but you need the 12 bolt 6 lug axle shafts.
  12. 87sm465np208
    Aug 28, 2002
    1,114
    illinois
  13. MJB774X
    MJB774X 1/2 ton status
    Sep 26, 2002
    574
    SO CAL
    careful swaping 10 and 12 bolt stuff, axles look almost identical, the only difference is the thickness on the end of the axle close to where the c clip goes, 12 is a little thicker then the 10, almost made that mistake myself having two axles pulled all apart at the same time. good luck!
  14. 87sm465np208
    Aug 28, 2002
    1,114
    illinois
    i will, i just gotta get a god dang axle.
  15. 87sm465np208
    Aug 28, 2002
    1,114
    illinois
    so your tellin me that the diameter of the 5 lug and 6 lug 12 bolt axles are the same diameter and they will interchange with no hassle, besides pullin em out and puttin em in.? /forums/images/graemlins/deal.gif
  16. kennyw
    Jun 9, 2002
    13,224
    94
    I think he was saying the axle shafts are close but DONT MIX THEM UP.
  17. 87sm465np208
    Aug 28, 2002
    1,114
    illinois
    people at junk yards are tellin me that the 12 bolt 2wd rear end shafts are bigger then the 4wd shafts.
  18. kennyw
    Jun 9, 2002
    13,224
    94
    I can tell you from experience...
    I have a 2wd 12 bolt in my 1979 K10 right now. I am using the original 4x4 6 lug 12 bolt axle shafts in it and the original brakes. I have been driving it this way daily since Aug 1st. I put the 2wd shafts back into the 4x4 housing while I am rebuilding it and they are a perfect fit also.
    The only thing you dont want to do is put 10 bolt axle shafts in a 12 bolt /forums/images/graemlins/thumb.gif
  19. 87sm465np208
    Aug 28, 2002
    1,114
    illinois
    hey thats cool, well i have no one to take me to junk yards, and im sick of takin off school to goto a junk yard and only find junk that i cant use (wrong fu*king ratio's) so im taking the 12 bolt my friend gave me with the 3.24's and takin it to the shop tomarow and havin them put the RIGHT gears in it to match the front, so i have the same front and rear ratios, and plus i will be upgradeing from the god awful 10 bolt and into a slightly more heavy duty axle that will take what i can dish out ( i know this from what my friend put his axle on his old truck though that had a 12 bolt rear, he used to do serious burn outs in parkin lots that would bury the needle on the spedometer) ill tell ya'll how it works out.
  20. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    Why not just regear the front? your truck would probably have a little more pick-up with the lower gears.
