What do you think of this winch from harbor freight?
Discussion in 'The Garage' started by jjlaughner, Jun 26, 2003.
  1. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
  2. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    I think I would be leary of Harbor freight. The grinder's, and belt sander I have bought, are underpowered, and "overrated".
    It's Your coice though. With a 2 1/2" drum diameter, it's gonna really coil that cable up, when it unspool's, it might look like a coil of fishing line, all tangled, and twisted.
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    If it's of the same quality as most of the other stuff that they sell at Harbor Freight, it's probably good for 2-to-5 uses before it's broken. /forums/images/graemlins/eek.gif /forums/images/graemlins/frown.gif (Assuming of course that you aren't stuck really badly the first time!) /forums/images/graemlins/wink.gif
  4. yeild2me
    yeild2me 1/2 ton status
    Jan 7, 2001
    1,309
    fayetteville, nc
    Got Snickers?? Cause you "wont be going anywhere for a while" with that 1.8 hp motor and gearing!!
    Then again.....maybe better than a come-a-long or at least may get ya unstuck.
    Rob
  5. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    said something like 339. For not much more, I'd get a milemarker 8k/9k electric. Maybe 100-150 more, but at least I know it will work when I need it to.
    A buddy of mine got a harborfrieght one, similiar to yours. It worked, but it only lasted maybe 4 pulls, before it melted itself.
  6. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    I inquired about that winch last year. I received several responses about it not functioning or burning up when under load. Someone said they were repackaged low-end Ramsey's. I decided against it.
  7. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    I doubt that. I think Ramsey stuff is still made in the USofA. Pretty much everything that Harbor Freight sells is Made In China.
  8. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Harbor Freight IMHO= Salvaged good's from sunken ship's. /forums/images/graemlins/rotfl.gif
  9. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    ITS JUNK....
    Whats your life and your rig worth on the side of a hill???
    made by some guy getting 10 cents and hour and working in a sweat shop....
  10. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    Allllllll-righty then! /forums/images/graemlins/blush.gif
    What do you guys think of their pipe/tubing notcher (42324-1rxa) for $39.99
    and their
    horizontal/vertical bandsaw (37151-7rxg) for $169.99
    Both made by central machinery /forums/images/graemlins/ears.gif
  11. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    I am thinking of getting one to mount on my trailer to get non running vehicles up on it.
    Thats about all I would use it for.
    Ken H.
  12. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Quick Hijack... /forums/images/graemlins/grin.gif What about their Hydraulic shop press? it's a 25 ton, I think. $89. Would use it on u-joints and carrier bearings... /forums/images/graemlins/ears.gif
  13. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    I have in My possesion, one of the bandsaw's, it work's o.k., the blade's are'nt worth a dime though. /forums/images/graemlins/rotfl.gif Go to local saw shop, and have them make a few, decent metal cutting blade's. /forums/images/graemlins/grin.gif
  14. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    They sell no 25 ton hydraulic press for 89 bucks. I do however have their 12 ton model which I bought for $109.00 It has been a life saver.
  15. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Yep, their cheapie press is just 12 tons. I've got one that I bought probably 10 years ago. I don't use it often, but when I need it, there is no other tool that will do the job. /forums/images/graemlins/cool.gif The jack leaked when I first got it, but they replaced it under warranty for me. The frame is very narrow on their presses. I think that's one way they keep the cost low. Keeping a 3-foot-long I beam from bending under 12 tons of pressure is way harder than when using just a 2-foot-long I beam. Sometimes it's a real pain in the a$$ to balance a part, while trying to operate the jack, because the frame is too narrow for the part to fit properly on. /forums/images/graemlins/frown.gif For example, a 3/4-ton hub and rotor won't fit on there all the way when pressing studs in or out. /forums/images/graemlins/shocked.gif But for $89 it does a decent job on small stuff.
  16. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    That winch looks like the MM and I wasn't impressed w/ it at all. I have one of the saws you asked about, but mine has an Enco label. You can find it in all kids of brands, but they are all made in the same factory. The blades it comes w/ will be junk. Get some good ones, as stated above, and you will be OK. I have had a hard time keeping mine cutting straight, but that might be more of an issue on mine, because it was a freebe put together from parts of broken saws, and I haven't heard anyone else make the same complaint.
