What do you think ????
Discussion in 'The Garage' started by mudhound72, May 7, 2005.
  1. mudhound72
    mudhound72 1/2 ton status
    Feb 15, 2005
    474
    Oshkosh, WI
    Do you think that a stock Chevy truck mirror will hold up to a 102” CB antenna attached to it. I just dont know if the extra weight and force on will snap it off.
  2. jhellwig
    jhellwig 1/2 ton status
    May 7, 2005
    420
    Bonaparte, Ia
    If the mirrors are anything like mine they will fold in while driving and shutting the doors.
    The rear bumper works.
  3. diesel4me
    Jul 24, 2003
    17,561
    942
    Massachussetts
    Not a good place..
    Maybe a fiberglass whip,but a stainless steel 102" whip + a spring?--I dont think it will like it much!..plus your cable will get all frayed from the door closing on it in no time flat..your better off in the rear,or using a rain gutter mount,or on your roofrack if you have one--the signal pattern is best when mounted in the center of the vehicle more so than when an antenna is mounted on one side--the signal tends to be strongest diagonal to the side the antenna is mounted on,if mounted on one side..--
    On my 72 K5 I put the antenna is several locations and tested it out--it was best mounted on the spare tire rack in the passenger side rear quarter,the signal went mostly towards the drivers side front that way--best for reaching drivers coming at you in the opposite direction on the highway..I found running a ground wire helped lower my SWR ratio a lot too..the carrier was mounted in rubber "well nuts" that didnt allow for a good ground!.. :crazy:
  4. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i have my 60" cb antenna on the roof of the cab, works real good, cept it hits trees every now and then, but its alright, its an antenna
