what do you think?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 80K5, Jul 7, 2001.
  1. 80K5
    80K5 1/2 ton status
    Jun 5, 2001
    100
    Ok, I am planning to go with a 4" shackle flip in the rear and 4" Tuff Country EZride springs up front. Do you think this will give me some decent flex. And are there any concerns I should be aware of before going with this lift? Thanks!
    Steve
  2. Grim-Reaper
    7,385
    Atlanta
    Yes.
    Here is a link to Depdogs stuff. He runs the same set up but uses rear springs from a Mid 80's K5. I run almost the same set up except I got some stiff Rancho's that don't flex in the front. Dep also did some shock relocating tricks that are detailed on this site.
    <A target="_blank" HREF=http://www.off-road.com/chevy/projects/rockready/>http://www.off-road.com/chevy/projects/rockready/</A>
    It's not my damn planet monkey boy!
    <A target="_blank" HREF=http://communities.msn.com/OffroadK5s>http://communities.msn.com/OffroadK5s</A>
    Grim-Reaper
  3. 80K5
    80K5 1/2 ton status
    Jun 5, 2001
    100
    I have an 80 K5. Is there any difference between an 87 and an 80's rear leafs?
    Steve
  4. Grim-Reaper
    7,385
    Atlanta
    Yeah a ton. Softer spring rate, Teflon pads between the leaves. Rides so much better than the older leafs. Not sure when they changed them. Sometime in the mid 80's. My 79 and 75 both had much stiffer springs. I have 86 springs on the 75 and looking for another set for the 79.
    Grim-Reaper
