What do you use to flare Stainless Brakelines??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Boss, Mar 14, 2001.
  1. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    Ok, here is my dilemma,
    I bought some stainless steel brake lines for my rear 14bolt. I bought them straight and bent them in place. I bought a little too much (by like 2 feet) and have to cut and flare it. First I tried cutting it with my tube cutter, nope, chipped my freakin cutter blade too![​IMG]
    Then I tried the sawzall, nope, too violent. So I broke out the air powered cutoff wheel. Worked great!![​IMG] Should've used that first.
    Now, got that figured out. But when I tried to flare it, after I tightened down on the line really hard with the flaring tool, but everytime I spin into it, the line just slides down the tool and not flare out like its suppose to. This stainless steel line is SO TOUGH!!! TOO Tough!! I should've stuck with steel. [​IMG]
    Do any of yall have any suggestions or ideas? Is there a Flaring tool out there made specifically for Stainless Steel lines?? I'm stumped! Thanks for any help. Take care.
    Boss
    <A target="_blank" HREF=http://www.boss.coloradok5.com>http://www.boss.coloradok5.com</A>
  2. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    Hey Boss I would of thought that a good double flare tool would do the job that is what your useing right? You mite give your locale brake shop a call. good luck Eric
    Lost? i'm not lost i'm just disorienated
  3. Cavalry
    Cavalry 1/2 ton status
    Oct 1, 2000
    978
    upstate NY(although I cant figure out why)
    I dont know what brand of tube you are using but inline tube claims to be able to flair with a regular flair tool....is the tool in good shape?
    Luke
    84 K5
  4. WhiteWhomper
    WhiteWhomper 1/2 ton status
    Sep 23, 2000
    227
    Highlands Ranch, CO.
    I've run into this problem before, and I did the easiest and cheapest solution, I heated the end of the tubing. You have to get it pretty hot, but then it flares great. Oh, in no way can I guarantee proper results, but try it on some scrap tube and don't quick cool the piece. Let it cool slowly.
  5. thatK30guy
    Jan 12, 2001
    32,076
    55
    Like Highlander says, use a double flare tool. This is all you need to make the job go easier. A regular flare tool wont make the right flare for these brake items, which are VERY important part of a vehicle.
