What does a FF14bolt spool look like?
Discussion in 'The Garage' started by Skyetone, May 2, 2002.
  1. Skyetone
    Skyetone 1/2 ton status
    Apr 10, 2002
    118
    SLC Utah
    I have seen a powertrax that is like a sauser that replaces the spider gears. It isn't that. I just tore down a FF and the long side shaft was busted at the hub. I thought about it and looked into the carrier. Well it looks like a toyota detroit to me. It is a solid peice that screws together at the ring gear through three screws. Inside where the shafts slide in is a solid plate. There is no acces to the spider gears through the carrier without unscrewing it. There is also some filters on the carrier. It looks nothing like the open diff I have. It had 4.10's on it though. Is it a LS? Can someone help this idiot out and throw me some pix?
  2. burbBoy
    burbBoy 1/2 ton status
    Feb 4, 2002
    358
    WI
    If its screwed together and has screens on it it sounds like a gov loc to me. I know someone on here has some good pics of both open and gov loc difs.
    Brian
    82 burb, 38.5's, SM465/NP205, 10/14 bolts
  3. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    There are no 14 bolt spools
  4. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    I just read they are making spools for 14 bolts now...can't remember who or what post I read with that info though.
    Rene
  5. greatwhitenorth
    greatwhitenorth 1/2 ton status
    Mar 10, 2002
    102
    Surrey, BC
  6. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
  7. Skyetone
    Apr 10, 2002
    118
    SLC Utah
    It definetly is a GOV lock. Is that a corporate FF then? I don't get what a corporate is.... So it's a LSD then? How limited or how mutch slip? Is that a stock item? I know of another 14bolt FF that has a LSD in it but never saw what it looked like.
    I just pulled the stock diff apart and put it back together. Had to pull a detroit out and put back in spider gears. Does a detroit just replace the spiders in a FF? In toy its a carrier. Don't ask why the previos locker was pulled. Can I just bolt on the ring gear4 and reset up back lash and be done? Thats all I did with the open carrier.
