What does a HEI/ESC control
Discussion in 'The Garage' started by jeff l, Jul 7, 2006.
  1. jeff l
    jeff l 1/2 ton status
    Jun 13, 2006
    104
    New Orleans
    I am taking a 305 out and puting a 350 in, I think I can connect every wire/senser, but the wire going to my old Q-Jet
    These are options
    1 Put Hei in and connect every wire
    2 Put Hei in and do not connect 2nd set of wires
    3 Convert my Hei/esc to regular Hei ( I heard you can cut wires and conect others)
    4 Buy new just Hei
    I just don't know much about HEI/ESC and what it controls and what would I lose if i don't have ESC. and what would it do to the computer
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    The only thing to installing a regular HEI is to drop in the distributor and connect the power wire .
    Mine is like that , the ESC wires were cut , the ends saved in my tool box , and the wires stuck in the harness conduit taped up .
  3. jeff l
    Jun 13, 2006
    104
    New Orleans
    So you had a HEI/ESC and just cut the ESC wires off and every thing was ok
    Did you lose anything?
  4. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    IIRC, you can't just cut the ESC wire, it will permentaly retard your timing. I can't remember the procedure, but I think you need to jumper 2 wires on the dist-to-esc module connector on the distributor side.
    Do some searches on google for esc bypass or esc disable, i did this many years ago attempting to troubleshoot a problem.
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    You didn't get what I said . I dropped in the HEI distributor i.e THE WHOLE NEW DISTRIBUTOR . Which requires just a power wire .
    This obsoleted the resty of my wiring !!
    The ESC/HEI distributor is in a box in my garage . I refuse to let it get within 3 feet of my truck .
  6. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,073
    486
    Grand Rapids area
    There are three options:
    1) Run the ESC and hook everything up like it was on the 305.
    2) Convert the distributor by replacing the 5-pin module with a 4-pin module (available everywhere) and replacing the one harness (also available at many parts stores).
    3) Convert the distributor by bypassing the ESC module. You just have to jumper the green and black wires together (pins A and C in the 4-way weatherpack connector).
    For either option 2 or 3, you don't need the ESC module that came from behind the glove box. You can remove the harness by taking off the "piggyback" power connector from the distributor hot lead. There is also a ring terminal to ground which attaches to the passenger's side head.
  7. rlhenry
    rlhenry Registered Member
    Mar 6, 2002
    93
    Morenci, AZ
    When I converted mine I replaced the pick-up coil to the older style to work with the 4 pin module. If you jumper the wires does that eliminate the need to convert the pick-up coil? If I'm not mistaken, the harness from the pick-up coil has the 3-way connector for the 3-pin side of the ignition module.
    I went through 2 ECM's before I converted. That was about 8 years ago and I haven't had an ignition problem since.
  8. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    So much work . I could of done that too . The whole dizzy was easier and has a warranty :thumb:
  9. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    yeah I just dropped in a whole distributor... I had one sitting on the shelf, and the new, rotor, cap, and coil I had installed on the old one swapped right over.
    I decided to get rid of the ESC when I accidentally left the ESC wire off and the truck wouldn't start, couldn't figure out why it had no spark.... Until I found the wire crammed down between the bellhousing and body.
