What does a K5 + FJ40 + a trailer weigh?
Discussion in 'The Garage' started by Bone85K5, Apr 6, 2005.
  1. Bone85K5
    Bone85K5 1/2 ton status
    May 7, 2000
    436
    Columbus, Georgia
    Any thoughts? Assuming the trailer is not a 5th wheel and big enought to fit both.
  2. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    ...a S-load! :D
    seriously tho, w/ stock vehicles i'd guess in the neighborhood of 12-14k lbs??
  3. Joshinator
    Joshinator Registered Member
    Jan 19, 2005
    58
    Sulphur Louisiana
    A WHOLE Lot
    i thought the same as Jonny-K5, but more. give or take a few hundred pounds, i figured each rig to be in the 5k area, and a trailer that big, id guessed it would be in the neighborhood of 10k by itself... Hope you have ahelova tow rig!
  4. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    ya, more i think of it, probly closer to 16-18k. i think you'd have to get a 5th wheel to tow that much weight. trailer probly would weigh around 6-8k.
  5. Bone85K5
    May 7, 2000
    436
    Columbus, Georgia
    tow rig is a
    Tow rig is my dd 2004 Diesel Excursion 4x4
  6. Bone85K5
    May 7, 2000
    436
    Columbus, Georgia
    also form the specs i googled...i found generally:
    blazer weighs 4462
    fj40 weighs 3263
    total of
    7725 without a trailer.
    Anyone towed their blazer and another truck??
  7. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    I towed an FJ 40 to Moab last week and with my truck, trailer and cruiser it was 13,300 lbs. My truck weighs 6700, trailer 2000, so cruiser must = 4600. My 4X fullsize weighs 5700ish so total would be 12,300 lbs but I'm sure the trailer to haul them would be heavier.
  8. jrpeebles
    jrpeebles Registered Member
    Jan 19, 2005
    40
    North Hollywood Ca.
    I would not think that you would be able to tow that amount of weight safely without a 5th wheel/gooseneck and dual rear tires.A friend of mine tows a toyhauler loaded with a jeep and quads,which weighs in around 13,000 lbs with an Excursion and it can be a little squirrely.
  9. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    There is no way an FJ40 only weighs 3300 lb. Closer to 5K would be a lot more like it.
  10. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    I'd also like to see this 4,400 lb. Blazer!
    A typical fullsize Blazer, especially if it's trail-prepped, if going to be around 6,000 lb. An FJ-40 is also relatively heavy for it's size, I've never weighed my basically stock '71 FJ-40, but I would guess it's well over 4k. That's 10k in the two vehicles, and I would think a trailer long and heavy enough to hold both would be at least 4-5k.
