What does a smallblock without casting numbers mean?
Discussion in 'The Garage' started by CyberSniper, Sep 21, 2004.
  1. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    I have had a SBC sitting around for a while... I always assumed it was a 350.
    I decide to scrape the casting number area clean. To my dismay, it says "GM 5.0L G" which I assume means a 305 gas motor.
    Is there a way to identify what is inside without tearing it apart? Is there any chance that it has roller lifters? If it were a roller 305 it would cover up some disappointment.
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    what are the suffix, the ones in front of the pass head?
    never seen what you have /forums/images/graemlins/dunno.gif
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Yep you got a 305, I had the same thing happen to me a while back. /forums/images/graemlins/rotfl.gif
    Pull the intake to look for roller lifters.
  4. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    is that the one out of the black longbed?
  5. diesel4me
    Jul 24, 2003
    17,553
    939
    Massachussetts
    Thats the trouble with small blocks--they all look the same--kinda like a vagina!--I had a friend that works at a boneyard ask me if I knew anyone with a 400 SBC for sale--I told him he had one lying on the ground near a 72 GMC pickup--he said "no way,thats the 307 POS out of that truck"--I told him he'd better go take a better look at the flywheel and damper!he looked and he was /forums/images/graemlins/blush.gif /forums/images/graemlins/blush.gif!.He ran that motor hard for 2 years,even after sitting on the ground all year in the rain it still survived!.
    I have never seen a block without the BIG casting numbers near the bellhousing,but the other numbers near the altenator are often milled off when they deck the block during a rebuild,if its a factory short block it might have all zeros,or the suffix CE on it(stands for complete engine)
    as for the roller lifters,I asked all the chevy guru's I know,they all said what Tim said--pull the intake,its the only sure way to tell(I didnt because they didnt start the roller lifters till 87,I have an 86)--its like the 4 bolt mains,there are lots of things that might point to it being a 4 bolt(certain casting ##,oil plugs near timing cover,etc)the only sure way is to pull the pan.
    Dont be too dissapointed you got a 305 instead of a 350--another guy bought a "350" and had me install it in his truck--he thought it was awful doggy for a 350,so I looked up the engine code--turns out the impala he bought the motor out of had a swap before it hit the boneyard--it turned out to be a 267!! /forums/images/graemlins/tongue.gif /forums/images/graemlins/crazy.gif /forums/images/graemlins/screwy.gif
  6. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    check out the site Mortec.com. They have a lot of info on casting numbers......... /forums/images/graemlins/thumb.gif
  7. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    JFC
    I can't read the small numbers underneath it.
  8. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Yeah, I knew I got a 305. I'm just trying to recover from the swift kick to the crotch. If I'd known it was another f'n 305 I'd have yanked the transmission and taken the whole f'n truck to the junkyard instead of burning up $100 in acetylene/oxygen cutting it up. Not to mention the last 10 months of it sitting in my yard wearing out its welcome with the neighbors.
    I don't really want to pull the intake, but I guess I'll have to. It's odd. Looks original but yet it has that "GM 5.0LG" on it plus has perimeter bolt valvecovers.
  9. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
  10. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Well, from my limited experience, vaginas aren't all similar. Some are as beautiful as a mechanically-injected Corvette 283 and others are as disasterous as a 1985 California smog truck 305. /forums/images/graemlins/rotfl.gif
    This 305's casting number looks kind of like this one.
    The problem is that I have no shortage of 305s. I could use another 350.
  11. ben427
    ben427 1/2 ton status
    Mar 10, 2002
    1,123
    Waverley, Nova Scotia
    did you look on the whole bellhousing boss??? Like over on the right hand side instead of the left, on 86 up motors ive seen them there, and the 5.0GL where your showing it. By the sound of your engine, its an 86-88, a mutt if you will. One piece seal with perimeter walve cover heads, ill bet the heads have the later intake pattern with the 72* intake manifold bolts too does it??
  12. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    [/ QUOTE ] /forums/images/graemlins/shame.gif
    Can't let this go /forums/images/graemlins/whistling.gif
    They may look similar but they are not all the same, vagina that is /forums/images/graemlins/ignore.gif
  13. wasted wages
    wasted wages 3/4 ton status
    Dec 3, 2003
    9,194
    Dallas Texas
    Some are just bored out bigger than others. /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif
  14. Emmettology 101
    May 9, 2000
    8,126
    FL
    Ya, they did start putting those types of numbers on the bellhousing lip around 86 and started to mainly go by the number on the lip below the head. You said you cant read them, are they machined off or just gunked up? Most places will ask you for the 3 digit letter code that I think is before the number string. Even if you call Summit with that letter code, they can tell you what vehciles the block was used it. I've had a few blocks like that and checked the codes.
    I didn't think truck roller engines started until early 90's?
  15. ben427
    Mar 10, 2002
    1,123
    Small blocks except for the truck engines were roller from 87-up. This includes, corvettes, cop cars, caprices, camaros, anything that wasnt a truck, and had a small block.
  16. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    You were right, it had the casting numbers on the bellhousing over on the passenger side.
    14088551 1986-87 305 flat tappet, one piece rear main
  17. GMCLegacy
    Jan 24, 2002
    620
    Grand Haven, MI
    time to build a coffee table
  18. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
    My thoughts exactly.
  19. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Maybe I'll decide to port this piss out of the heads, run a solid flat tappet 274 cam, ARP it, hypeutectic flat tops, and stick a 100 shot on 'er. Swap 'er into a S10 and see if I can kill myself. 400 horses out of a 305 would be a blast. Who needs powerboost brakes anyway?
    But it'll probably collect rust in the corner. I don't even think this motor is worth buying an engine stand for. It aught to do a fine job of keeping the concrete floor from floating away.
    f'n 305s.
  20. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    f'n 305s.
    /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif Sorry....
