What does every one think of this?
Discussion in 'The Garage' started by thefarside, Oct 21, 2003.
  1. thefarside
    thefarside 1/2 ton status
    Jun 27, 2003
    343
    Vernon, CT
    I have a 86' K5 and I noticed that it needs some front end parts, ball joints tie rod ends. Plus I was planning on putting 39.5 TSL or the new IROK's on it and unfortunately it is a 10 bolt front and rear. What if I swapped out the entire suspension from my newly rebuilt 80 K5? Think every thing would fit? /forums/images/graemlins/thinking.gif
  2. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    It should fit fine. I assume you mean suspension and drivetrain. May need shaft or u joint changes.
    I won't give you the spiel on 39's on half tons, you know what you're getting into.
  3. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    iroks are very light tires for their size... and 36" iroks may be able to work on your 1/2 ton axles. I wouldnt even think about using 39.5s tho..
    j
  4. thefarside
    Jun 27, 2003
    343
    Vernon, CT
    Yeah just the axles, I was planning on buying an 8" inch BDS lift and maybe a shackle flip too. Between that and some fender trimming I should be able to accommodate the 39.5"s. I tell you, man I wish I could just find a fairly cheap 14 bolt and D60 for the front though. It would make life a lot easier!
