What does my truck hate me (Part II)
Discussion in 'The Garage' started by shaun, Feb 22, 2004.
  1. shaun
    shaun 1/2 ton status
    Apr 22, 2003
    745
    Well the breaks are still all f'd up but now there arte more problems. I changed the oil and filter (while I was taking a break from the brakes) And now when I run it it blows white smoke. Now it is a little cold outside but not that cold? There is also some water in the tail pipe (I know this is supposed to be normal) and a little condensation on the dipstick. Could this be a blown head gasket? Please say "No shaun this is just normal" (unless that is not the truth, then tell me the truth. Also just put in a new radiator, thermostat, hoses and the fluid we took out didnt look oily, it just looked normal. /forums/images/graemlins/confused.gif
  2. unick
    unick 1/2 ton status
    Aug 16, 2003
    4,286
    San Diego Comufornia
    its pretty drizzely out here after work and in the mornings so water is always dripping out of my tailpipe unless I have driven it for a while. It always smokes when I start it up but it goes away after a while.
    Nick
  3. shaun
    Apr 22, 2003
    745
    Even white? Maybe its because It hasnt been driven in 8 days and I just changed the oil? That would be good news /forums/images/graemlins/woot.gif
  4. unick
    Aug 16, 2003
    4,286
    if its oil i think the smoke will be a blueish color but im not sure
  5. shaun
    Apr 22, 2003
    745
    I think you are right that if it is burning oil it will be blue. I will waut till morning and check some more stuff out. I hope it isnt a blown head gasket. /forums/images/graemlins/eek.gif
  6. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Doesn't sound like it....Pull the plugs, and look for one that is very clean.
  7. bshewmaker
    bshewmaker Registered Member
    Sep 11, 2003
    79
    Arkansas
    I've blown a few head gaskets, and I always experienced massive loss of power, and it ideled like it had a huge cam. but if you havent driven it you wouldn't notice the power part
  8. shaun
    Apr 22, 2003
    745
    It hasnt lost any power but the smoke just scares me a little. Why pull the sparkplugs? What will that tell me?
  9. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    first keep a CLOSE eye on your coolant level...If you don't have anyleaks and you have a blown head gasket, the level will go down...
    Does the white "smoke" stop after your truck heats up to operating temps? Do a compression check and also pressure check the cooling system.
    A little white smoke is normal in cooler temps when the eninge is below operating temps (its just water vapor that is converting from a gas to a liqud)
    Chris
  10. shaun
    Apr 22, 2003
    745
    I think that is all it is but I will check again.
  11. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    As you probably know, water is a part of the combustion process. You get "smoke" coming out of your tailpipe when the exhaust isn't hot enough to keep the water from condensing. Here, in the great white U.P. a vehicle's exhaust rarely gets hot enough to stop "smoking" in the wintertime. Which is why they rust so fast.
    Anyway, go drive it around. If it doesn't go away then I'd worry about it. Watch to see if other people have "smoke" also.
    If you run 50/50 coolant and you were burning a significant amount of coolant you'd definitely be able to smell it. If you're a typical crazy southerner that runs straight water or maybe a wee bit of water wetter then you won't be able to smell the burning antifreeze. Cooked antifreeze burns your nose pretty good. If it's burning a significant amount of antifreeze (like if you'd notice if you drove 50 miles) then it'd burn your eyes too.
