What does PTO refer to?
Discussion in 'The Garage' started by colbystephens, May 2, 2006.
  1. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    i did some searching and read alot of references to winches and whatnot, but still don't really understand what it is. What does the acronym mean? is it a winch which runs off of your tranny or t-case? if so, how do you run the cable out from under the truck without hurting anything? school me.
  2. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    power take off, it is a box that mounts to your t-case or tranny that has a gear drive in it that can drive a small d-shaft or hydro pump. most popular manufact. are chelsea & muncie.(that i work on anyhow).
    can be used to drive a "pto" winch or a hydraulic pump for a dump bed, etc.
    usually has a cable mounted or air mounted control to engage it. then the device it drives will have a control also.
    there are 2 mounting patterns for them, our t-cases & tranny's use the small pattern ones. eaton big truck trannies use the larger pattern usually.
  3. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    IIRC its power take off, which means it uses a t case to work.
  4. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    SM 465 and NV4500 also have PTO ports on both sides of the tranny's. It's not just a t-case thing.
    Rene
  5. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    so what would be a practical use on a k5?
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
    Nothing really. Unless you find one of those HUGE PTO operated Garwood winches in the larger 2.5 and 5 ton military trucks. :eek1:
  7. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    ok, well i'm going to take it upon myself to find a d@mn good use for one and then sell it to all of you. ;) we'll see what i can come up with!
  8. theperfectgarage
    theperfectgarage 1/2 ton status
    Oct 5, 2005
    988
    tucson arizona
    Yeah, your just getting creative on coming up with bucks for your new transmission. :D
  9. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    nah, the money side of things is not the concern for this swap - i'm getting an unbelievable deal, it amazes me how good this deal is. but i have a hard time with the concept of leaving well enough alone. :) if it's got the possibility of some constructive use, then it's going to be put to some constructive use. :D
  10. theperfectgarage
    Oct 5, 2005
    988
    tucson arizona
    Well, carry on then.
  11. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    well, i'll send you a free one just b/c you went to the same school as my wife, only in a previous millenia. :wink1: so don't be too upset. :D
  12. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    A good use for a PTO is to run a hydraulic winch. A Chelsea PTO hooked to a small gear driven hydraulic pump. Most parts you could scavenge off of an old tow truck...
    Rene
  13. R77K10
    R77K10 Banned
    Mar 15, 2006
    564
    Lincoln IL
    lots of trannies have PTO opening
    including the 420, 435, 465,
    and transfer cases and other stuff
    use them to operate dump beds, roll backs, plows, etc
    they most comonly drive a pump which is used to move cylinders in the above and other applications
    on a k5 i dont knwo what you could do with one other than a plow
    thats about it really
    good luck
  14. boz42
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    u could build a hydro margarita blender big enough to supply everyone in camp, in fact u build it, buy the liquor & i will meet up w/ u to drink.
  15. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    well, i'm not much of a drinker, but if that's what the market demands . . .
    rene - how would you keep the cables out of your running gear/engine/body/etc?
  16. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    so i've been considering the aforementioned invention quite a bit recently, and realized that i don't have a d@mn clue what i'm working with. :D it would seem to me that such a contraption could only be run off of a truck in motion (or at least with wheel spin), as this is the only time the gears in a manual tranny or t-case are moving. is this correct?
    that might limit my imagination. :( but its ok - i'll still invent something super kick @ss, so don't fret, be assured, the gears in my head are spinning. i will have something which will make you want to give me money (as i know you are all so eager to do). :haha:
  17. ct85k10
    ct85k10 1/2 ton status
    Oct 25, 2005
    121
    Charlotte, NC
    for the transfer case ptos that is corect but one off the transmision will spins unless the cluch is engaged
    colby t
  18. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    so you could potentially run it in neutral or when the vehicle is moving, correct?
  19. protechk5
    protechk5 1/2 ton status
    Sep 26, 2004
    2,015
    VA
    Yeah so on a tranny, where is the pto or gear located? If your saying the clutch has to be engaged, would the pto spin fast if you were in a higher gear? Like put the t case in netural and then put the tranny in 4th. Does anyone get what Im saying? It probably doesnt even matter how fast in spins.
  20. ct85k10
    Oct 25, 2005
    121
    Charlotte, NC
    i dont think it maters what gear it is in because the transmission can be out of gear and the pto still spins when you let off the cluch at least thats how it works on my grandfathers bucket truck
