What does the "shackle flip" consist of?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by calvin, Jan 6, 2002.
  1. calvin
    calvin 1/2 ton status
    Oct 23, 2000
    152
    Brownstown, Michigan
    What does the \"shackle flip\" consist of?
    Just curious. Pics would be great.
    BTW, is there any easy way to make up for the 1/2" of sag in the rear of my 79? Someone told me I can the bottom spring around or something???
    <a target="_blank" href=http://irocz.cz28.com>http://irocz.cz28.com</a>
    79' Chevy Custom Deluxe shortbed K10, 396 ,pics on site
  2. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    Re: What does the \"shackle flip\" consist of?
    if you want the ORD flip check out Jason's(jekrown) write up
    <a target="_blank" href=http://www.communtiy.webshots.com/user/jekbrown>www.communtiy.webshots.com/user/jekbrown</a> It's just a bracket that is wellengineered to achieve a 4" lift with stock springs.
    to get rid of the saggy but get the ORD 1" add a leafs..theres a write up in the tech sections, sorry no linky.
    <font color=red>Life is like a mud hole:</font color=red><font color=blue>
    When the S#!T gets deep, you have to keep moving and friends can always pull you out</font color=blue>
    55 Willy's
  3. calvin
    Oct 23, 2000
    152
    The link won't work. So you recommend the 1" add a leafs over the shackle flip? Am I reading that right?
    &lt;a target="_blank" href=http://irocz.cz28.com&gt;http://irocz.cz28.com&lt;/a&gt;
  4. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    I put the "i" in the wrong spot on my first post.<a target="_blank" href=http://www.community.webshots.com/user/jekbrown>Jason's Flip kit install</a> It will give you a 4" lift in the rear, to eliminate the current set up, I take it you have blocks?? But if all you want is to bring the rear up that 1/2" or so just get a <a target="_blank" href=http://coloradok5.com/ordaddaleafreview.shtml>1" zero rate from ORD</a>.
    55 Willy's
