What does this BB I found in the tranny pan do?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Sample, Feb 25, 2003.
  1. Sample
    Sample 1/2 ton status
    Oct 15, 2002
    536
    Apache Junction, AZ
    Well, if I haven't had enough problems with the K5 thus far. It stopped moving in any gear. Every gear acted like the transmission was in nuetral. This is the 700R4. I pulled the pan and found a BB in the bottom along with some grime. I cleaned it all up, put in a new filter and gasket and refilled it. It now shifts fine, actually better than before I had my problem. What is the purpose of the BB and how long until my tranny totally dies on me?
    Thanks,
    Chris
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    It is probably a check ball from the tranny valve body. These BB's tell the tranny when to shift.
  3. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Thanks,
    Chris
    I am just worried how it fell to the pan /forums/images/graemlins/confused.gif
    It's a check ball and there is no way it can pass from the valve body to the pan without damage.
    /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
  4. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    Well I can't see how it got there, I know it's from the valve body. I don't know what I would do about either. Maybe get a shift kit and install it at lest you would know that the BB's are in the right spot. I'm sure one of the tranny gurus will see this and have better imput for you.
    Eric
  5. K1Orion
    K1Orion 1/2 ton status
    Jan 8, 2003
    812
    st.louis,MO
    Its a check ball from the valvebody like others said. If somehow it still shifts, better in your opinion, then just drive it.
    If it gives up you will have to rebuild it.
    If it keeps working you aren't out anything.
    I guess you you could open the pan back up, drop the valvebody and try to find out where it came from? Not sure how you would tell where it came from though. /forums/images/graemlins/confused.gif
  6. 90K5Blazer
    90K5Blazer Registered Member
    Jun 10, 2002
    48
    Dayton, Ohio
    Stop driving it and spend an hour and put in a shift kit. There cheap and you will know you have your balls in the right holes. /forums/images/graemlins/ears.gif
  7. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    Thanks,
    Chris
    After some thinking, I don't believe this check ball fell on it's own, either you or the PO has dropped the valve body at one time and it fell, maybe even replaced it and didn't fish out the old one.
    I can't imagine a route where it can end up there otherwise.
    So if it's driving fine keep it untill it craps out, then you will know.
