What does your temp. gauge read?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by not4show, May 5, 2002.
  1. not4show
    not4show 1/2 ton status
    Apr 24, 2001
    280
    Alabama
    Along the way I have changed the engine, dash, radatior, tempture gauge and everything in between on my truck. However, recently it's reading hotter than what it had been. It reads at almost half way under everyday driving, where it used to read at about 1/4 from the left. So, I put a new thermostat in to see if that would fix it, but it did not. The last thing that I changed before it read hotter was the dash. I don't think it runs any hotter than it did, I just think the gauge could be off. It maybe because I changed the dash. I was just wondering what most of your 1st generation dashes are reading normally?
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Mine reads 1/4 from the left. I have a 160* t-stat.
  3. JIMs70K25
    JIMs70K25 1/2 ton status
    Dec 31, 2001
    524
    Chesapeake, VA
    Mine reads 1/2 scale. 190 deg thermostat.
  4. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    Mine reads about a needle width below the "normal" range normally, and just into the normal range when I'm really banging on it. I've tried six different gauges and 4 sending units. All read pretty close to the same. I run a 160 degree Robertshaw thermostat and a Rodney Red aluminum radiator.
  5. not4show
    Apr 24, 2001
    280
    Alabama
    Thanks guys.
