what dose ping sound like
Discussion in 'The Garage' started by screamer*145, May 18, 2004.
  1. screamer*145
    screamer*145 1/2 ton status
    Oct 23, 2003
    174
    cottage grove, mn
    just like the post dose i sound like lifter tick or will bad time cause lifter tick my timing is set at 8 deg. before, i run 92 oct. with about 10-10.5 comp. any ideas it just started happening and never did it before? /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/dunno.gif
  2. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    I can't resist.
    It sounds a whole lot like ding.
    /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
  3. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    A ping sounds exactly like that, a ping. Like the sound a ball peen hammer would make if you smacked the top of a piston with it.
  4. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
    When I advance the timing in my car too far (11to1comp). it sounds like its squeaking /forums/images/graemlins/rotfl.gif
  5. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    You know the sound that a can of paint makes when you shake them up and that little beebee in there bounces around? Well it's like that cept faster as your motor pulls more revs than you arm can manage. That is unless you have a hell of an arm and lots of practice starin at magazines and........................................................ /forums/images/graemlins/eek.gif /forums/images/graemlins/yikes.gif
    /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
    Good luck to y'all in the future. /forums/images/graemlins/thumb.gif
    Allan
  6. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    WHy is everyone replying to me? I didn't ask the question... Apparantly whatever it is a ping sounds like, it's not the same sound for everyone. What it DOESN'T sound like is a lifter tick. /forums/images/graemlins/wink.gif
  7. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    it sounds just like this
  8. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    When does it do it?
    Preignition(pinging) can be heard when the engine is under a load, like when ya stomp the pedal or pullin a hill.
    Kinda sounds like rocks in a coffee can.
    When pullin a hiil if it starts to ping let off the throttle and see if it goes away, step into it and it comes back.
    If it just started check the timing first.
    If it sounds like a ticking then it could be a lifter that needs to be readjusted.
    Or it could be an exhaust gasget leaking.
    Like Shaggy said pinging does not sound like a tick.
  9. screamer*145
    Oct 23, 2003
    174
    cottage grove, mn
    then it looks like i have a lifter tick or some thing becuase i checked for exhaust leak and found none. what would cause lifter tick! /forums/images/graemlins/thinking.gif
  10. thezentree
    thezentree 3/4 ton status
    Sep 19, 2003
    7,198
    NC
    sounds like a screwdriver bein knocked back and forth in the jaws of a pair of pliers in my truck
  11. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
  12. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    OK, kind of on topic. What are some easy things to try to get rid of ping before ripping the motor down. My 305 pings something awful. I have a motor I will be swapping in but it will be at least a month before I have the time.
  13. mrk5
    Apr 20, 2004
    12,349
    1,050
    Northern Colorado
    The easiest thing would be to try retarding the timing.
    Or you can get into adjusting the mechanical and vacuum advances. There are kits available to do this.
  14. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    So is everybody saying here that valve pinging cannot be caused by worn out valve seats and guides?
    Because i seem to remember replacing some heads that were just wore out and were in need of new seats,valves,guides and so on.
    They were making this pinging sound, the best way i can determine or "hear" it, to me it sounds like a small Diesel engine. The rattles.
    Currently my engine does this under hard acceleration, but i am contributing this to the 212k miles on it.
  15. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    Cracked heads can also cause this... My truck has been this way for the last 50,000 miles or so, maybe more. I'm going to be swapping in a diesel soon though to replace it.
