what drill bit do you guys like for metal???
Discussion in 'The Garage' started by boggerless, Oct 8, 2006.
  1. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    i got a set of craftsman wood and mild steel that cuts better than the craftsman metal bits.i was drilling the holes for my floor in the bed and the bits where breaking like they were made outta pretzels.:mad: we used to sell a sweet set of titanium bits at work that were so good you could drill a 1/2 inch hole using only the 1/2 inch bit.now drilling a pilot hole and building up 5 bits and they still busted.POS so what do you cats like?? thanks daryl
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i usually use cobalt bits, they last quite a while. ive broke a few of the smaller ones and wore out the more common sizes (1/4, 5/16, 3/8, 7/16, 1/2) but the one i bought came in 64ths so i still have a few good ones left.
  3. 76zimmer
    76zimmer Flyin Rat Premium Member GMOTM Winner
    Nov 14, 2005
    23,031
    1,347
    Kzoo, Mi
    Titanium, bought a set at Sears, and they're holding up pretty good. Of course some tapping fluid always helps make the going easier.
  4. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    A good set of coblat. They are the best bits available... Expensive but well worth it in the long run:wink1:
  5. boggerless
    May 26, 2003
    22,728
    96
    i snapped everyone you just mentioned??WHAT UP TJ?????? PM me your # again. cobalt huh?who sells those?
  6. boggerless
    May 26, 2003
    22,728
    96
    the ones i got at sears looked like the titanium we used to sell but they couldn't cut the cheese.i'll save e'm for drywall.:haha: :haha:
  7. nutsthename
    nutsthename 1/2 ton status Premium Member GMOTM Winner
    May 29, 2006
    350
    Pageland, SC
    I buy 135 degree split point for work. They work very good. I've used a 1/2" bit on a 14.4v battery drill on 1/4" steel.
  8. Slapperbar
    Slapperbar Retired Navy NDT Examiner Premium Member
    Nov 29, 2005
    2,747
    3
    Harrison City, Pennsylvania
    Black and Decker Bullet Bits
  9. rdn2blazer
    rdn2blazer 1 ton status Premium Member
    Jun 9, 2004
    16,487
    1,192
    So Cal.
  10. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,228
    485
    New Hampshire
    I got some Ryobi titanium bits and they work real good. They slice through metal like a hot knife through butter. I drilled out 16 frame rivets with 1 drill bit. 3/8 I think.
  11. fireplug
    fireplug 1/2 ton status
    May 3, 2005
    1,692
    Toronto, Canada
    Cobalt hands down, but you are spending some $. Any specialty tool supply will have them. If you want to reduce spending and still get a good cutter, try Blue Mol, I picked some up at Home Depot, very very good bits, I believe the ones I picked up specified metal use, but I could be wrong. As mentioned split point is the way to go as well.
  12. 79BRUISER
    79BRUISER 1/2 ton status
    Jul 6, 2006
    739
    Indiana
    at work we use HD super premium black and gold, we get ours from Fastenal, but thier expensive, come real close to outcutting cobalt, my cobalt set from mac cost me 225$, and thier only warrantied from 1/4" on up. Dont know if fastenal sells sets, but you might call them.
  13. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    check out snapon.com
    then buy a set of dbtr129, best bits you'll ever own...
  14. uao85
    uao85 1/2 ton status
    Jan 2, 2004
    1,867
    Edge of insanity
    for steel, I use either bosch titanium nitride or something like that, or I use another brand called blue mol.........amazing bits, drilled straight through 1/4" plate (edit:with a 1/2" bit)about 2 dozen times back to back non-stop, kept giving it a drop of oil here and there and it performed flawlessly.
    Remington
  15. fireplug
    May 3, 2005
    1,692
    Toronto, Canada
    Yeah oil is a very important part of the game. You can also get a paste like product that works very well, and is also useful if you are drilling something that is vertical or above you.
  16. Slapperbar
    Nov 29, 2005
    2,747
    3
    I've always used Tap Magic with no problems.
  17. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    I would stay away from Hitachi (Home Depot) after going through 2 in rapid fashion over the last week.
  18. diesel4me
    Jul 24, 2003
    17,546
    937
    Massachussetts
    on metal??..
    The best drills for metal are SHARP ones!..I find the Cobalt and Titanium ones to be great when you first use them,but once they dull,they seem worse than a regular high speed steel bit..I've melted a few of them!..
    I find a nice SHARP bit works well,even if its not a bona fide "HSS" or Cobalt,Titanium,or M2,or whatever..I have to re-sharpen my drill bits after 4 or 5 holes,especially if I'm using a hand held electric drill..you can get away with sharpening them less often if using a drill press..
    I can't really specify any particular brand of drill--I've used Black and Decker "Bullit" bits,they are OK,but I don't feel they drill any faster or better than regular bits..I bought a bunch of them for a buck apeice at a flea market,and have about exhausted my supply..they do not "wander",or walk around,which is nice,no center punching needed..but once they dull,good luck trying to re-sharpen the double pointed end!..I usually just grind them into a regular looking bit,to get a few more uses out of them..
    I have bought "cheap" M2 drills at "Job Lot" stores that held up great,and some expensive ones from Vermont American,Craftsman,and "Bosch" brand,that didn't impress me much..many dulled right away,and actually cut better after my crude attempts to sharpen them freehand on my bench grinder!..I buy mostly cheap bits,or "good used" ones,because I break more than I end up keeping for long..:doah:
  19. boggerless
    May 26, 2003
    22,728
    96
    NO KIDDIN?? what i tried first with the "METAL BITS" :rolleyes: all it did was skid around.
  20. boggerless
    May 26, 2003
    22,728
    96
    i hear ya on the breakage...i was useing a 1/2 inch electric drill and i was doing good until i realized that the metal was different in hardness depending on what hole i drilled.????i could go right through one hole and the next was like i had the drill in reverse. but the very next hole the same bit worked???HA HA the sweet ones we sold at work my friend left on the dumpster and guess what happened.
