what driveline mods need to done with a 6"-7" lift?
Discussion in 'The Garage' started by bigoltrux77, Sep 18, 2003.
  1. bigoltrux77
    bigoltrux77 1/2 ton status
    Jun 12, 2002
    318
    Fort Polk, LA
    what driveline mods need to done with a 6\"-7\" lift?
    I was wondering what i have to do to the driveline to allow a 6-7" lift on a newer K5? How much is it going to cost? Thanks
  2. bigoltrux77
    Jun 12, 2002
    318
    Fort Polk, LA
    Re: what driveline mods need to done with a 6\"-7\" lift?
    btt
  3. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    Your shafts should have enough slip in them - if not use spacers to lower your t-case a bit.
    If not, its about $80 or so to retube a shaft.
  4. ColAdo82K5
    ColAdo82K5 1/2 ton status
    Feb 18, 2000
    789
    MO
    Well....
    Steering...just a rasied steering arm, but a dropped draglink to go along with that would be good. If you are really going to wheel it, try crossover steering.
    Brakes...longer lines, there are napa numbers floating around here. I use them on my 6inch lift and they work great.
    Driveshaft...When you say "newer" i'm guessing you have a 208 or a 241 case with a slip yoke. I just had a longer shaft made but sometimes you can get into vibrations. So a CV shaft may be in order or lowering the TC to get the angles right. YOu can convert to a fixed yoke if you want to try that way.
    It all depends on the amount of lift and what you are going to use the truck for.
    Blake
  5. mudskipper
    mudskipper Registered Member
    Sep 13, 2003
    29
    Rohrersville, MD
    I just had a cv shaft made for my 88. although it has a 60/14ff i couldn't believe the differance. if it's only going off road it probally wouldn't be that bad. the vibes on the street were bad on mine. /forums/images/graemlins/angryfire.gif /forums/images/graemlins/k5.gif
