what else do i need to regear 14FF?
Discussion in 'The Garage' started by desertrat67, Sep 1, 2006.
  1. desertrat67
    desertrat67 Hawk Driver
    Jul 5, 2001
    3,982
    74
    Dumfries, VA
    I am goingto regear my rear axle this weekend and want to know if I am mising anything for the install. So far I have:
    1. R&P
    2. New Carrier(lower gears)
    3. Master install kit from randy's
    4. Access to a press for the bearings
    5. Torque wrenches(ft/lb for bearing caps and in/lb for pinion bearing preload)
    Is a dial indicator all i need besides this or am i missing something? thanks
    ryan
  2. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    you dont need a new carrier just buy thick gears and put them on the 4.10 and down carrier.:D
    Other than that it appears all you need is a dial and a mag base. I warmed my bearings and ring gear on the BBQ grill to install them. The oven will work the same but be careful on either method to not overheat them and change the properties of them. It does not take much heat to make them expand:D .
    Ira
  3. desertrat67
    Jul 5, 2001
    3,982
    74
    Dumfries, VA
    Already bought the gears for the other carrier(lower split carrier came with the truck when i bought it. Will a dial with the vice grip base work or ony one with a mag base?
  4. k5freak44
    k5freak44 1/2 ton status
    Jun 1, 2004
    2,164
    Plano, TX
    you sound like you have everything you need. just dont forget paitence
  5. sandawgk5
    Oct 28, 2003
    6,881
    That will work just need to make sure it does not move:D
    Ira
