What engine do I have?
Discussion in 'The Garage' started by turtlenut2, Jun 24, 2006.
  1. turtlenut2
    turtlenut2 Registered Member
    Jun 23, 2006
    6
    Vermont
    I made a deal with my cousin to change his engine. He supposedly bought a 350 that I had to pull out of a C60 firetruck. It appears to be a small block chevy (it had an adapter plate, so that it would hitch up to the monster standard tranny) the harmonic balancer appears to be from a 350 but the flexplate that came off his old 350 doesn't have a big enough centerhole to fit the crank. I was told that it has to have 3 freeze plugs on the side if it's a 400sb (it has 2). How can I tell if it's a 383? Or am I just looking at it wrong?
  2. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    It may be a tall deck 366/427 truck engine.
  3. MTChevy
    MTChevy 3/4 ton status Premium Member
    May 6, 2005
    7,141
    78
    Great Falls, MT
    got some casting numbers?
  4. turtlenut2
    Jun 23, 2006
    6
    Vermont
    How do I tell?
  5. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    First off, how many bolts holding the valve covers on? 400 SBC's came with either 2 or 3 freeze plugs on the side so that doesn't help you any. 383 was not a factory GM engine but rather a stroker engine that people commonly build. How many bolts holding the intake manifold on?
    How about taking a pic of it for us to determine SBC or BBC. With the info i just gave we can determine that much for you anyways.
  6. turtlenut2
    Jun 23, 2006
    6
    Vermont
    There are 4 valve cover bolts each. 12 Intake manifold bolts. casting numbers I found 3970010 and E145. Also has left side dipstick.
  7. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    3970010 is a 350 chevy, could be either 2 or 4 bolt main.
  8. turtlenut2
    Jun 23, 2006
    6
    Vermont
    4 bolt main with 2 peice rear seal. My problem is finding flexplate that will fit the crank. I've ordered one for a 350 but the center hole is too small.
  9. sweetk30
    Nov 1, 2004
    25,526
    526
    horseheads , ny 14845
    if you orderd one for a 1 peice rear seal newer motor the crank style is diffrent. soinds like that.
    my friend pulled a 350 from a c60 bus and didnt have any real problems.
  10. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Hmmm... I know there are slight differences on the 350s that came in the heavier trucks. The heads have larger accessory holes for example. Perhaps the crank is unique also? :confused:
    If all else fails, try the stealership ;)
  11. 76zimmer
    76zimmer Flyin Rat Premium Member GMOTM Winner
    Nov 14, 2005
    23,029
    1,347
    Kzoo, Mi
    I think the commercial applications used a unique setup for the flywheel flange on the crank, as they used bigger diameter flywheels.
