What exactly does this tool do?
Discussion in 'The Garage' started by RustBuket, Feb 15, 2005.
  1. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    This may seem like a dumb question to some but what does this tool do?
    http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=32718&item=3874774673&rd=1
    Also, there is a tool which I don't know the name of it but I believe it has the purpose of cutting thin sheetmetal kind of like a scissor. They have one on monster garage and I think its pneumatic. The metal thats cut comes out in a thin strip and coils up. What is that tool called? looks handy. Thanks.
  2. sweetk30
    Nov 1, 2004
    25,526
    526
    horseheads , ny 14845
    its like a saws all but cuts like a scroll saw great for tin work
    almost the same kind of tool
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    .... the tool you described is known as a nibbler... look at the name of the tool on there. There are lots of ways to cut sheetmetal, there are electric and pneumatic shears, as well as electric and pneumatic nibblers. You are probably thinking of the shears. But a nibbler is a good tool, sometime I will get one, can make better curves and such with it.
  4. ryoken
    Jun 13, 2003
    29,621
    1,371
    Jersey Shore
    i own both an air nibbler and air shear... the shears make the coiled strip.. nibblers make tiny halfmoon chunks...
  5. stano
    stano 1/2 ton status
    Jan 24, 2005
    130
    Iowa
    We have one and it was a whole lot less money than that one. (Can't remember but maybe $100.00 maybe $150.00. at local tool shop.
    It has a plunger shaft about 3/16" maybe 1/4" that goes up and down and pushes into a hole. The plunger nibbles off about a fourth of a hole of 3/16". Which it punches out half moon peices. Rapidly. It does not warp the body metal that it is cutting. works good on long quarter or long body part because of no warping of the sheet metal edge.
    The only bad part is you have a whole lot of half moon pieces that are very sharp and get stuck in every thing. Shoes, hose, tires, hands. but if you clean up right away than there is not problem.
    I like the one we have. Especially like i mention working on long body parts like rear quarters because on the non warping edge it leaves.
    87 K5
    thank you
    stano
  6. RustBuket
    Feb 21, 2003
    1,618
    Thanks guys, if I get the welder I want this spring for bodywork, I may invest in one to make things easier. Thanks again.
  7. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    Those things work great, I trimmed my inner fenderwells with mine. Makes quick work of it and turns super tight corners. Don't walk in the garage in bare feet after using it though...:blush:
  8. RustBuket
    Feb 21, 2003
    1,618
    Good tip!
  9. 85burbanator
    85burbanator 1/2 ton status
    Feb 10, 2003
    577
    lake orion, mi
    i cant stand wearing shoes in the summer. i weld,cut,grind,wrench,walk,run do everything barefoot. last time i went to chicago i forgot my shoes at home so i had to by some flip flops. any way, i was thinking of getting some nibblers. anybody have experiece with both tools(nibblers and shears i think there called)?
  10. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Shoot, don't walk on them things at all. Had one go right thru my work boot's sole.
  11. k5freak44
    k5freak44 1/2 ton status
    Jun 1, 2004
    2,164
    Plano, TX
    i have experience with nibblers, shears, cutoffwheel, jigsaw, sawzall for cutting sheatmetal. the nibblers are the easyest to follow a line of anykind, straight or curved. the shears work well too and can cut a little bit thicker metal but dont pivot/ turn aswell as the nibbler. Cuttingsheetmetal with cutoffwheel. jugsaw or sawzall is alsogood too becasue you can cut alot thicker metal with a decent amount of control.
    sheetmetal - NIBBLERS DEFFF
