what exaust would you do/recomend for a caddy 500??
Discussion in 'The Garage' started by y5mgisi, Apr 30, 2005.
  1. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    Just about to that point now that i got to start figuring that one out. My current plan is to run the factorie style "Y" pipe and then do singel 3" after that with just a glasspack, but have it run all the way out the back. Does this sound like a good idea? the truck allready is set up for duals (has dual 2 1/4" till the muflers which are both blown up and missing tailpipes) but then id basicly have to buy twice the exaust parts to keep it dual. So what would you do?
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Are you going to be reving the motor to the moon? If not I would just use a highflowing 3" single system. If you are after some high end horsepower with a motor that size you will want something a little larger then 3" I would bet. Probably 3.5" or 4" exhaust or 2.5" duals.
    I have dual 2.25" exhaust on my K5 and it was cool for awhile, but now I wish I had a single 3" system. The duals take up to much space and cost to much when cats and stuff go out.
    Harley
  3. originalspanksta
    originalspanksta 1/2 ton status
    Jan 31, 2005
    147
    Philadelphia
    Actually the single 3" flows better than dual 2.5's. more cross section area for the exhaust to flow thru.( i think. Im drunk right now and i cant really remember crrorectly)
  4. big_truxx
    big_truxx 1/2 ton status
    Oct 8, 2004
    2,272
    Canaan, Maine
    dual 3" w/ turbo mufflers :waytogo:
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    stock 78-85 c-10 diesel 350 pipes and manifolds, and they are dual from factory and one of the two manifolds has a blockoff that can be removed for use with a y pipe, i have a pair i can get you casting codes if need be, they are common,
    good luck
  6. smalltruckbigcid
    smalltruckbigcid 1/2 ton status
    Dec 25, 2004
    3,866
    3
    NE Wyoming
    I think you're refering to the olds diesel 350, those won't fit the heads. Personally I would go with the single 3 inch, especially if you keep the rpm under 4000 for the most part.
    George
