what exhaust R U running with ur 383
Discussion in 'The Garage' started by mini_mull, Mar 1, 2005.
  1. mini_mull
    mini_mull 1/2 ton status
    Jan 22, 2005
    1,198
    Queen Creek, AZ
    Just wondering what exhuast everyone is running with their 383s. What Headers, Cats, Mufflers, Pipe diameter, dual or single? Need input so I can make plans for my upcoming swap. The more info about your total setup, the better. Thanks. Oh, and include if you like your setup, or if you would have done anything different.
  2. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,995
    133
    I have flowtech headers going to 2.25" dual pipes with no cats and 40 series flowmaster mufflers. I don't think my exhaust is restricting any power, it was pretty cheap, has lasted almost 5 years, and sounds awesome. I would recommend it.
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Anything over 300 HP or so and you're losing power.
  4. Bullet
    Bullet 1/2 ton status
    Mar 14, 2001
    1,222
    Abilene, Texas
    Edelbrock TES headers, 2.25" tubing, no cats, single FLowmaster 40 series muffler and dumped before rear axle. Sounds mean as hell. Going to swap a Super 40 before too long to replace the old muffler.
  5. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    On my 87 K5 with the HT 383
    Edelbrock headers and Y pipe. 3" magnaflow performance cat. 3" 50 series delta flow muffler. Real mandrel bent 3" tailpipe. 4" tip
    John
  6. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    I am using Hedman 1-5/8 primary headers with 3" collectors, dual 2.5" pipes into dual 40 series Flowmasters. From the mufflers back, I have 3" pipes running straight out the back.
    I may change the tail pipes to angle out behind the wheels one of these days.:D
  7. sandy78
    sandy78 Registered Member
    Nov 28, 2002
    84
    Utah
    I am running Hooker headers w/ 2.5" collectors, Hooker's mandrel bent dual 2.25" pipes w/ Summit's Turbo style mufflers. My exit is out the side, but rocks have not been kind to it. How many exit out the back, and how bad are the fumes? Top on, and Top off.....
  8. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    i dont have a 383 yet, but when i do i'm keeping the thorley headers,single 3" mandrel bend pipe, and 3" high flow cat off my 350 setup, but swapping the 40 series flowmaster for a 3" magnaflow. i dont think this will choke off any power, the motor im planning on supposedly makes 310 hp and 410 tq.
  9. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    i've got a single 3" pipe exiting out the side behind back tire. its noticeable with top on, back window down. stopped or at any speed. the low pressure behind the truck forces the fumes in. probly wouldnt notice at all with top off, but i've never taken mine off.
  10. spoolnaround
    spoolnaround 1/2 ton status
    Apr 8, 2002
    1,419
    Kingsburg Ca
    When my 383 was in my Chevelle I noticed a major decreas in power between the Cyclone headers and 2.5 duel exhaust and the cheapo headers and 2.25 exhaust. The 2.25 had more bottom end, I think I will go back to the 2.25 when the 383 goes into the Blazer.
