What exhaust
Discussion in 'The Garage' started by bigboy, Nov 28, 2005.
  1. bigboy
    bigboy Registered Member
    Nov 8, 2005
    51
    Lafayette, IN
    What exhaust should i get that will have a nice sound for cheap for the k5 with a EFI 350? I eventually plan on putting headers on it also.
  2. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    I've used regular old thrush turbo mufflers on several of my projects when money was the main guidline. you can get them at advance auto parts, autozone, etc. and they are only 12-22 dollars depending on inlet and outlet size and which model you buy.
  3. big94gmc
    big94gmc 1/2 ton status
    Sep 1, 2004
    3,651
    No VA.
    40 Series flowmasters :D
  4. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    I use Walker DynoMax's from Summit. They're not for those who like it loud though.
  5. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    He said for cheap. I don't think $70 per muffler qualifies.
    I seconds the thrush mufflers. I had a pair of their turbo mufflers on my chevelle (350sbc, edelbrock performer intake and 1407 4bbl carb, hooker headers and 2 1/2" dual exhaust). It had a nice *chug, chug* sound at idle, real mean like. Then when digging in the 4bbl at 4k rpm it howled. :bow:
    Now given the choice, I would use the flowmasters 40 series (I happen to have a pair a friend gave me when he replaced his duals with single exhaust to pass emissions here) :D
  6. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    Cheap??!! Get some glasspacks!! The cheap Turbo's from Autozone n Kragen are pretty restrictive. A buddy of mine ran a pair because he's cheap. Later he spent a little more for some better quality mufflers and could feal a difference. Look into Flowtech "Purple Hornies" or Summit and Jegs are selling some Force Pro Series mufflers that have a deep throaty 70's Muscle Car sound. $25-$30 each. Try to get some that are welded. My cousin and I have blown out some rolled seem mufflers. If you want to dish out the coin check out the Flowmaster Super 40 series. Deeper tone, with less interior resonance. I use 'em on my Moded '00 Mustang GT. The K20 runs older 40 series and is LOUD. My 63 Merc with 390 has Dynomax Ultra Flow's for a quieter deep sound.
  7. YELL78
    YELL78 Registered Member
    Feb 27, 2005
    54
    ALBUQUERQUE
    i have a custom exaust on my 78 its got a 2 1/2 y-pipe routed behind and under the transfercase then goes to single 3" with one of those force 2 flowmaster copys the muffler was like 30 bucks from jegs and it sounds great and with the single 3" tail pipe i have great low end torque.
    the truck had duals when i bought it and i put the single and the truck runs way better.
  8. gravdigr
    Apr 15, 2003
    1,129
    Tyrone, PA
    Some things are too cheap. I have a great personal dislike for glasspacks. Also keep in mind he is running what appears to be a stock 350EFI, an exhaust that's too open may cause problems.
  9. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    flow super 40's ;)
  10. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I say call performance curve exhaust they are a vendor on here and have very good prices. As for me I am going to run a high flow 3" cat and a flowmaster super 40 and run the tail pipe between the spring and the frame tucked up nice and tight.
    Ira
  11. oneofthefewbmx
    oneofthefewbmx 1/2 ton status
    Oct 6, 2004
    579
    Copperas Cove, TX
    i run flowmaster 40 series w/ an x-pipe on my 383...**** sounds mean....
  12. bigboy
    Nov 8, 2005
    51
    Lafayette, IN
    Cool thanks guys I am probly just going to run it like it is until i can get enought extra cash to get some flowmasters, tips, pipes, and headers so maybe febuary or march because I really need to do some floors and floor supports and also REALLY need and want some suspension.
  13. trailblazr81
    May 27, 2005
    931
    Hollister, CA
    Jegs, Summit, and JC Junkyard all have kits that include pipe, mufflers (or not) tips and all mounting hardware. This could be a good choice as long as you dont go wild on engine mods.
  14. bigboy
    Nov 8, 2005
    51
    Lafayette, IN
    I dont really plan on doing much to the motor maybe a bigger cam and some little stuff.
  15. K5Steve
    K5Steve 1/2 ton status
    Aug 10, 2005
    288
    Carson city, nv.
    :bow:
