what exles have 4.11?
Discussion in 'The Garage' started by obijuan, Jul 23, 2006.
  1. obijuan
    obijuan 1/2 ton status GMOTM Winner
    May 18, 2006
    4,009
    San Antonio TX
    what Gm axles that i can put on my 85 k5 have 4.11 or similar ratios? K20 or 30, burbs? im thinking of just getting a set from pick n pull all ready to go but need to know what to look for. id rather not regear. its about 100 dollars per axle at pick n pull. thanks alot!
  2. spoolnaround
    spoolnaround 1/2 ton status
    Apr 8, 2002
    1,419
    Kingsburg Ca
    k20 yes. not sure if any of the k10's had 410's or not. Yes that includes subs. A K30 will need to have the spring purches moved.
  3. obijuan
    May 18, 2006
    4,009
    San Antonio TX
    are they still 6 lug or can i just swap the brake assembly to keep my rims? are the driveshafst still going to be the same lenght?
  4. diesel4me
    Jul 24, 2003
    17,561
    942
    Massachussetts
    options..
    GM did have 4.11's available in 1/2 tons,I had a 75 K5 with one in it--it was 2wd too!...but if you are planning to off-road it,3/4 or 1 ton 14 bolt SF or FF is the way to go..a 10 or 12 bolt 1/2 ton rear isn't really up to the task of hauling big heavy tires and rims off road..for the same money you could get the 3/4 or 1 ton rear most likely..
    They had 6 lug 14 bolt SF axles in some 88 and up "new style" GM trucks,but if I remember correctly,they had different spring pad locations,you'd have to cut them off and re-weld them in the right place for it to fit a 73-87 truck--might be wider too..All the other 14 bolts had 8 lug rims..not sure about the driveshaft,that varies from truck to truck...:crazy:
