What flexplate do I need?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 89GMCSuburban, Apr 6, 2004.
  1. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    89 with a 1 piece seal. I heard something about it being externally balanced... What tooth count is it?
  2. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    Need more info on the motor... 358 a stroker that uses a 400 crank or is it just an over bored 350 with a 350 crank? The only Chevy V8's that are externally balanced are the 400 and 454 as far as I know. Unless you have one of those cranks you should only need an internally balanced flywheel/flexplate.
  3. 89GMCSuburban
    Nov 15, 2001
    3,005
    Thornton, CO
    350 bored .40 over
  4. 89GMCSuburban
    Nov 15, 2001
    3,005
    Thornton, CO
    the current flexplate has a little weight on it
  5. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    It should be a 14" 168 tooth 'plate. GM PN 14088761
    John
  6. kennyw
    Jun 9, 2002
    13,224
    94
    If your current flex plate came off that motor/crank before you rebuilt it, you have the right one. /forums/images/graemlins/thumb.gif
  7. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    the 1986 and later 350's are externally balanced only on the rear.
