What fluid do you run in your Hydro Assist?
Discussion in 'The Garage' started by Poohbair, Jan 6, 2005.
  1. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    Like the title says... I know TONS of people (including myself) have always run ATF for PS fluid. Is this still a good idea w/ a hydro assist setup? Is it better to run actual PS fluid?
    What are you guys running and how does it work?
  2. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    when i first installed the WTO hydro setup. i bought some expensive PS fluid, then after the newness of the hydro setup wore off me, i just started putting atf in there.
    Although on the WTO website they say ATF is more prone to causing seals to dry out and cause leaks and such.
  3. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    i used the expensive pawer steering. cant remember the name but it was a goldish color at autozone. haven't had any probs
  4. white-rhyno
    white-rhyno 1/2 ton status
    Jan 27, 2002
    942
    Ellensburg Washington
  5. leadfoot067
    leadfoot067 1/2 ton status
    May 14, 2001
    1,563
    puyallup, washington
    napa power steering fliud,i get it in a gallon jug....need a gallon?
  6. sean'schevy
    sean'schevy 1/2 ton status
    Aug 5, 2004
    149
    New Egypt, NJ
    synthethic blend power steering fluid got it at auto zone
  7. jekbrown
    May 19, 2001
    45,030
    362
    Vancouver, WA, USA
    napa PS fluid. Im sure ATF would work fine too.
    j
  8. bigblock44k5
    bigblock44k5 1/2 ton status
    Jun 8, 2003
    396
    Hurlburt Field, FL
    You can use either, they are both esentially hydraulic fluid.
  9. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    From my automotive experience, I would recommend running p/s fluid. Keep in mind that ATF was specifically designed for transmissions while power steering fluid was specifically designed for power steering systems (duh, right?).
    It's not like p/s fluid is that expensive or hard to find..........
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I use power steering fluid because it's much thinner and thus makes it easier to steer, especially at low RPM.
  11. bigblock44k5
    Jun 8, 2003
    396
    Hurlburt Field, FL
    Correct it is thinner and easier to steer, but when you are crawling around on the rocks or them mud and you are giving your steering a workout, the fluid will heat up pretty fast. ATF will stand up to heat better than PS fluid.
