what fluid for a 208
Discussion in 'The Garage' started by tunedportk5, Dec 12, 2004.
  1. tunedportk5
    tunedportk5 1/2 ton status
    Jul 13, 2004
    371
    Union City, CA
    I'm putting my new tranny 700r4 in and the book I have says the transfer case takes 90wt gear oil for part time 4wd but when I drained it there was ATF in it. huh what is going on here.
  2. ColAdo82K5
    ColAdo82K5 1/2 ton status
    Feb 18, 2000
    789
    MO
    Yup, the 208 takes ATF ....Dex3.
  3. tunedportk5
    Jul 13, 2004
    371
    Union City, CA
    can the fluid from the tranny get into the tranfer case.
  4. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    shouldn't be able to. an Sm465 will leak gear oil out the output area into the adapter. But the input on the 208 is fairly well sealed up. ATF is what the 208 takes.
  5. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    208 and 241 take ATF
    203 takes motor oil
    205 takes gear oil besides a few late rare 205's that require ATF.
    Your th700R4 can leak fluid into the t-case but it is somewhat unusual, the higher the mileage the better the chance the rear seal will leak.
  6. BrianDamage
    BrianDamage 1/2 ton status
    May 14, 2001
    753
    Alabama
    the owners manual for my 87 says use atf
    never had a problem with it
