what fluid for NP205?
Discussion in 'The Garage' started by k5-newbie, Jul 22, 2005.
  1. k5-newbie
    k5-newbie 1/2 ton status
    Jun 19, 2004
    399
    Huntsville, Texas
    need to change the fluid...looks like it has tranny fluid in it now, just want to make sure that is correct.
  2. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    I put 80W90 in mine. :D
  3. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    I have had 205's with both ATF and gear oil in them. I heard that if you have a 205 mated to an automatic it is better to run ATF incase of a seal leak and gear oil mated to a manual.
    I can not verify this and ran gear oil instead of ATF mated to a TH 350.
  4. RootBreaker
    Nov 29, 2001
    5,118
    173
    Williamstown, NJ USA
    my trans takes 90wt oil..... and so does my np205 .....
    bough 1 gallon of gear oil from autozone & a nifty hose that goes onto the 1 gallon jug... :wink1:
    1 gallon = $6.50
    1 quart = $2.67
    so buying the gallons is cheaper even with buying the $4 adapter..
  5. dyeager535
    26,980
    Later on ATF was used. '91 I pulled was ATF.
    I switched it to 80W90 so it matched my tranny and diffs.
  6. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    I run 80w-140 GL5 cause I keep 2 5 gallon pails of it for the big rig trucks I have.
  7. k5-newbie
    Jun 19, 2004
    399
    Huntsville, Texas
    I didnt know you could run gear oil in a tranny, I have my 205 mated to a turbo 400 so can I run gear oil in it?
  8. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    gear oil if for manual trannys only only put ATF in your automatic tranny.
  9. 8_YOUR_H2
    Feb 20, 2000
    2,663
    Iowa
    Rumor has it if you run a manual trans and a 205 then you should put gear oil in the 205.
    If you have an automatic then you should put ATF in the 205.
    Hear say only. I have no idea on its validity. When I had a 205 mated to a TH 350 I ran gear oil in THE 205 and never had any issues.
  10. thatK30guy
    Jan 12, 2001
    32,076
    55
    All my shop manuals (pre-'85) listed 80-90 oil for ALL 205's.
  11. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    early manuals list 80-90, later ones (like my '83 manual) list ATF. Regardless, use the same oil you'd use in your diffs. ATF doesn't protect the bearings and gears the same as gear oil, the chart I saw showed a pretty big difference in bearing life between the two.
    If ATF gets into the case because of bad seals, it's not the end of the world, but I recommend starting with gear oil.
