What fluid in a hydro clutch?
Discussion in 'The Garage' started by RingMaster4x4, Jan 4, 2005.
  1. RingMaster4x4
    RingMaster4x4 1/2 ton status Premium Member
    Mar 4, 2001
    2,049
    Bartlett, Texas
    I am about to finish my SM465 swap and need to know what fluid goes in the master cylinder. Thanks for any help.
  2. 86chevybanshee
    86chevybanshee 1/2 ton status
    May 15, 2004
    917
    beverly MA
    i think u can use brake fluid
  3. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Dot 3
  4. RingMaster4x4
    Mar 4, 2001
    2,049
    Bartlett, Texas
    Can I use one of the higher rated ones? I only ask because the slave cylinder is close to the header.
  5. RingMaster4x4
    Mar 4, 2001
    2,049
    Bartlett, Texas
  6. readymix
    May 30, 2004
    6,706
    26
    you can go with 3 or 4. I am not sure about DOT 5 though.
    I used it in the brakes for my bikes when i still had them.
  7. RingMaster4x4
    Mar 4, 2001
    2,049
    Bartlett, Texas
    ok thanks
  8. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I am going to use Dot3 in mine. I think I remember reading someone using Dot5 and all was fine. Just don't mix or forget you got Dot3 in your brakes and Dot 5 in the clutch. The main reason I am sticking with Dot3 and cost too....
    Good Luck
    Burt
  9. RingMaster4x4
    Mar 4, 2001
    2,049
    Bartlett, Texas
    What temp will dot 3 withstand? The bleader is about 1/4 inch from the header. I am going to rap the slave cylinder with header wrap to help with the heat.
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    DOT 5 is not fine. Do not use DOT 5 in any of these trucks. It's nearly $30 a quart anyway.
    DOT 3 and 4 are totally interchangeable for our trucks since DOT 3 is all that is required.
    Just use DOT 3, it works fine and it's cheaper.
    DOT 4 gives you an ever so slightly higher boiling point but it's going to get 400*+ before it boils anyway, so don't worry about it.
    Clutch fluid isn't going to boil. The clutch system itself doesn't create heat like a brake system does. I wouldn't worry about it at all.
  11. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
  12. DieselSub
    DieselSub Registered Member
    Dec 31, 2004
    22
    Northern California
    There are also special fluids for clutch master cylinders.
    I have a Jeep Wrangler, that after replacing the clutch master cylinder, would have a very *un* smooth feel - kind of like it was sticking as I pressed the clutch down. I replaced the master cylinder twice, all the fluid, and still the same problem.
    Jeep was clueless and gave the standard dot 3 brake fluid answer, but GM has a special clutch fluid that solved my problem. If you run into this problem, give your local GM dealer a call and ask for this special clutch fluid.
  13. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Make sure you pick up some blinker fluid and a muffler bearing while you're there.
  14. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    and they will hand you a bottle of DOT 3 brake fluid. :screwy:
  15. DieselSub
    Dec 31, 2004
    22
    Northern California
    Laugh if you want. But I tried off-the-shelf DOT 3 in two different master cylinders for the Jeep. Each time I filled it up with DOT 3 and the clutch started to get squeaky and start binding after a week of driving. "Of course it's not the fluid, I just put new DOT 3 in".
    After searching all around the net I finally found a reference to GM's fluid fixing a problem similar to mine. I tried it out, and indeed it fixed my problem. I'm guessing the seals/bore on my particular master cylinder are sub-par in some way - I got them from Kragen :thinking: The GM fluid probably has greater lubricity to make up for the plastic bore.
    And yes, if you go to the Jeep dealer and ask for their "special" clutch fluid, you'll probably get DOT 3 for $10 a little bottle.
  16. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    LOL, I have to agree with you here. We use brake fluid in all the clutches that come through the doors and have never had problems.
