What fluid/oil to use in a NP205
Discussion in 'The Garage' started by adamforsythe, Jul 18, 2006.
  1. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    I will be FINALY installing my NP205 at the end of next week. I have been told I could use ATF or gear oil in a NP205? I would like to use the ATF just incase it started to leak back into my tranny. But I don't know if I would trust ATF in a NP205. What would you guys use ATF or Gear oil?
    Adam
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    Gear oil. Been discussed literally thousands of times. Do a search.
  3. wazzabie
    wazzabie 1/2 ton status Premium Member
    Apr 17, 2001
    1,721
    11
    Washington State
    When I got my NP205 it had tranny fluid in it. I'm not sure how long it had it in it but it runs OK. I took out he tranny fluid and put gear oil in it. I guess tranny fluid might save some mpg
  4. SchnorrCS
    SchnorrCS 1/2 ton status
    Oct 11, 2005
    368
    Loveland, CO
    If I recall correctly, teanny fluid goes in a 208. You sure it's a 205?
  5. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    Yea a few people (On this board) have said that you can use tranny fluid. But i'm going to do what I was going to do all along and use gear oil.
    Adam
  6. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,995
    133
    If you have an auto, I would go with ATF in the t-case. If you have a manual, run 80W-90. The 205 will run fine with either but you don't want to have two different fluids in case you run into a leaky seal.
  7. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    theres a search button, use it...:rolleyes:
    Gm used both atf and gear oil in 205's
  8. BizeeB65
    BizeeB65 1/2 ton status
    Oct 12, 2005
    859
    Louisville, KY
    x2 on the search button.
    I personally have asked this question before.
    I run ATF.
