What fluids to use?....
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Impex, Apr 6, 2000.
  1. Impex
    Impex 1/2 ton status
    469
    Chandler, AZ
    for the d44,12bolt, np205 and im still not sure what tranny i have its the 4spd. with low
    and how much does each take thanks!
  2. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    I have exactly the same stuff you do and I just use gear lube in all of it. The 80W90 kind or whatever its called. If you have a limited slip diff in the rear axle you need to use another type of gear lube made for that, but otherwise it won't matter.
    '73 K5
    Chevy good...Ford bad
  3. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    I just changed the fluid in my NP205 yesterday. I used Dexron III-ATF Fluid. I was told that was the fluid to use. Am I right? I hope so. But it sure didn't look like or was as thick as the previous fluid that was already in the case.
    Boss
  4. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    ATF is sometimes specified for the NP205 when connected to an automatic trans. Gear oil is always used when you have a manual (SM465) trans. Either one is OK for the t-case. I think they spec. ATF for t-cases used with automatics because the rear seal in the TH350 often leaks and mixes ATF with whatever is in the NP205 anyway. It is better to have all ATF than a mixture of the two.
    Tim
    1970 Blazer CST 4X4 350 SM465 NP205
    1987 Suburban 4X4 350
    1988 Chevy Pickup 4X4 350
  5. AZK5
    AZK5 1/2 ton status
    Feb 22, 2000
    448
    Chandler, AZ
    Thanks Tim, I'm soon replacing my NP203 with a NP205 that is sitting on my garage floor. I have a TH350 and assumed that all NP205's used gear oil.
    CB
