What fuel pressure - Qjet
Discussion in 'The Garage' started by mrk5, Jul 15, 2005.
  1. mrk5
    Apr 20, 2004
    12,332
    1,040
    Northern Colorado
    I just picked up an adjustable fuel pressure regulator so I could drop fuel pressure down to 1 or 2 on the trail.
    What should I set it at for street/highway driving? I'm thinking either 4 or 5.
    Oh, and I did search but almost all of the "fuel pressure" threads dealt with TBI.
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
  3. Mad-Dog
    Mad-Dog 1/2 ton status
    Mar 20, 2005
    548
    Ocklawaha,Fl
    5-7 psi is nominal fuel pressure, why on earth would you wanna drop fuel pressure to 1 or 2 psi on the trail....?
    I use a carbureted bypass regulator on a 7 psi mechanical pump to supply a constant 5 psi fuel pressure to the nitrous system and return any un-used fuel back to the tank, the carb gets a steady 7 psi fuel pressure.
    bypass regulators are nice because ant un-used is returned to the tank and not sitting stagnant in the line heating up.....cool fuel is good fuel.
  4. mrk5
    Apr 20, 2004
    12,332
    1,040
    Northern Colorado
    On angles it helps keep the needle from unseating on inclines due to fuel pressure since the angle will let the needle unseat easier than on level ground. Just one more way to avoid the expense of FI for a while longer.
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Scott , I run at 550 rpm in gear , and I don't stall . Your at a higher altitude , but I still expect the Q-jet to be allright with regular pressure numbers . They way the float and bowl are laid out is just much better , and the needle and seat are much more protected from slosh on these :D
  6. Mad-Dog
    Mar 20, 2005
    548
    Ocklawaha,Fl
    Oh ok, i learn something new everyday here at CK5.......thanx
  7. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    7 to 9 psi is stock mechanical carb pressure on Gm apps, like all of them really, v-8s, sixes, etc,
  8. mrk5
    Apr 20, 2004
    12,332
    1,040
    Northern Colorado
    Come to think of it, the people that I've talked to about running the regulator were using Holleys. Maybe it helps a holley more than it would a qjet.
  9. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Maybe you can take it back ( regulator ) and buy another cool little toy for the toy :D
  10. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    You shouldn't need a regulator with a Q-jet as long as you are using the stock pump. As said in above post they dont have slosh problems like Holley and Edelbrock. When set up right. A Q-jet is the next best thing to FI for off road. Q-jet AKA Hillbilly FI.
