what fuel pump to run with TBI
Discussion in 'The Garage' started by beater_k20, Mar 4, 2004.
  1. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    i made a deal to purchase a TBI setup last night for my 86. what do i need to do to make it work with my existing fuel tank senders? i'd like to retain my dual tanks if i can.
  2. k51989
    k51989 Registered Member
    Sep 19, 2003
    93
    Mishawaka, Indiana
    hey man this has nothing to do with your question, but this is the first time ive seen somebody post on here from the same area as me. i live in mishawaka. /forums/images/graemlins/k5.gif /forums/images/graemlins/peace.gif /forums/images/graemlins/thumb.gif
  3. justinf
    justinf 1/2 ton status
    Sep 23, 2003
    684
    Tuscola, Illinois
    You could go with the in tank pumps from an 87, they should work fine with your gauge and should fit into your existing tanks I believe. Someone correct me if I'm wrong.
  4. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    man, Mishawaka, that's CLOSE! i've got several friends who are OC Outlaws, so when i get my truck together it'll be in your neck of the woods quite often.
    Justin, do you know if the TBI engine harness has the connections for the fuel pumps built into it?
  5. justinf
    Sep 23, 2003
    684
    Tuscola, Illinois
    I think they do, but can't remember for sure. I can check with my brother in the morning, he has done two TBI swaps now, or hopefully either this weekend or next, I can check on the jeep I am picking up (it's going to have a TBI 350 in it that I will have to wire everything up when I get it).
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    email sent with part numbers.
    I'm going with an inline pump. I have two tanks and the factory setup is a wiring nightmare compared to what I'm doing.
    If I had an all factory setup I'd probably spend the time to go that route though.
  7. dyeager535
    26,979
    Won't work with your existing senders, since they are entirely different.
    You can run an external pump, but the senders are different internally...how the pump mounts does not exist on the earlier senders.
  8. justinf
    Sep 23, 2003
    684
    Tuscola, Illinois
    If you get the entire unit (pump and sender) it should fit in the tank and work with your gauge.
  9. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    I've done a few conversions. I have used both in tank and external. Either set up works equally well. The factory harness has an output to the fuel pump. If using more than one fuel pump you need to switch that output along with the level sender. I personally have had better performace from Walbro external pumps. I recommend staying away from the holly TBI external pump, I had one fail and it took them literally 8 weeks to take it apart and verify that it did not fail due to dirt, BEFORE THEY WOULD REPLACE OR REFUND.
  10. Grim-Reaper
    7,385
    Atlanta
    Got a link to the Walbro? I'm getting ready to do this conversion as well (if I don't go diesel).
  11. azblazor
    May 5, 2001
    1,953
  12. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I know that electric pumps don't like pulling, but does anyone see a problem with mounting the pump next to the transmission on the passenger frame rail?
    I've got dual tanks and I want to do the inline pump. The switchover cannot be pressureized, so it must occur after the switchover valve. Anyone see any problem with it priming? I figured I'd try it and see what happens. If that fails I've got to remove my dual tank setup, which I've been trying to retain. /forums/images/graemlins/frown.gif
