WHAT GEAR DO YOU RUN?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by purple89jimmy, Aug 16, 2001.
  1. purple89jimmy
    purple89jimmy Registered Member
    May 29, 2001
    75
    What gears are you guys running? and for what type of driving? I have 35's with a 700 and am considering going to 4.56's, but I don't know what rpm range that would put me in at highway speed. I have seen all of the tables, but I know there are a lot of 700's on this site, as well as 35 inch tires.
  2. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    I have 4.56's with the 700R4 and 33's and I love it.......Dan
    If it ain't broke.......Don't fix it....
  3. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I run 3.73's with 33"s - I usually run higher speed stuff (desert/sand/highway), so they are about perfect for me[​IMG]
    Dos mas Tecates!!!
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  4. RESTORE89
    RESTORE89 1/2 ton status
    Jan 31, 2001
    548
    CHAS SC
    411's and 33's
    great highway mileage and plenty of lowend torque
    It needs a bigger motor.
    what's in it now?
    doen't matter it NEEDS A BIGGER MOTOR
    89 350tbi/700r4h/np208/4.11's
  5. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    Insane Ewok Big-O 35x12.5x16 with 4.10's - SM465
    Jedi Mind Trick BFG 33x10.5x15 with 4.10's - 700r4
    Insane Ewok doesn't have OD, and even though it running bigger tires I like the combo...
    my tranny was blown on my first trip with Jedi Mind Trick so I didn't really get a chance to ascertain if I liked the combo or not
    <font color=blue> Jeff - may the force be with you</font color=blue>
    <a target="_blank" href=http://coloradok5.com/gallery/Jeffs-Stuff>http://coloradok5.com/gallery/Jeffs-Stuff</a>
  6. CCRider
    CCRider 1/2 ton status
    Jul 8, 2001
    314
    Charlotte North Carolina
    Currently running 4:56 gears and 37"swamper ssr's needs a little bit more though , just purchased 4:88's and will be swapping them in shortly , ran 4:56's w/35" bfg M/T's and it was about perfect for all around driving!!! if you need a little more I would not be afraid at all of going to 4:88"s !!! CC
    1991 Fullsize 5 1/2"lift, 37"ssr's,10Bolt8 lug , 14Bolt ff, 4:56 Detroit rear, 12"fr. 14"r Bilstein remote res.350 P.F.I , 700r4 , 241c W/ sye
  7. WhiteWhomper
    WhiteWhomper 1/2 ton status
    Sep 23, 2000
    227
    Highlands Ranch, CO.
    I run 3:73's with 36" swampers. Surprisingly, it does pretty good. Although 5:13 gears are comming soon.
  8. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    4.10's with 33's BFG's......Soon to be 4.56 adn 33" BFG's till I can afford 36" TSLr's
    Learning to fry bacon!! [​IMG]
    3/4 in progress[​IMG]
    <a target="_blank" href=http://www.nashvillek5.freeservers.com>www.nashvillek5.freeservers.com</a>
  9. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    Am running 3.73s with 35s, 700R4, and a weak 305. Not cuttin' it. Have a set of 4.56s ready to go in.
    Brian
    Click to see <a target="_blank" href=http://tx85gmcguy.alloffroad.com> My 85 Jimmy </a>
    Is it a bad thing when my reality check bounces?
  10. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color=purple> I'm running 3:42's with 33's but will e going to 4:56's when I put my new 35's on !
    L8r,
    . Riz . <a target="_blank" href=http://www.geocities.com/rizmonkey>www.geocities.com/rizmonkey</a>
  11. BLzr4x4ngkid
    BLzr4x4ngkid 1/2 ton status
    Feb 18, 2000
    703
    Wichita, KS
    I'm running 38's on 4.10's. I went from 3.42 in my 1/2 tons to 4.10's when I dropped the 14FF in and I can tell a pretty big difference. I'm also running a TH350 so I'm running about 2300rpm @ 65mph. I'll probably end up dropping in 4.88's or 5.13's. I'm still in debate with myself. Doing that would cancel all highway driving unless I get another 700R4. Overall it doesn't do bad.
    Pedal mashed and KICK'N ASS!
    WFO! Wide [censored]'n OPEN!
  12. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    Sounds like I'm the only one around with 3.07 gears and 31x10.50 tires that are actually 29" tall. I rarely go above 2500rpm with those gears.
    I can't wait to install the 3.73 gears I have. Someday I'll get 35" SSRs. I don't know if those gears will be fine for the 454. I'll guess they'll have to do it. I have a TH350.
    <font color=purple>//////
    <a target="_blank" href=http://blazer79.freeyellow.com>blazer79.freeyellow.com</a></font color=purple><font color=black>
    Soon a 454 K5!!</font color=black>
  13. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    4.11's with 35" SSR's (actual height of tire is 34.25") with a Turbo 350 (no OD) great combo for me, highway RPM's are perfect.
    Lots depend on your motor. Torquey motors don't mind a higher gear (lower numerically).
    <font color=blue>'79 ONE TON TPI K5 - See it at---&gt;<a target="_blank" href=http://www.blazzinor.rockcrawler.com>www.blazzinor.rockcrawler.com</a>
  14. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    SM 465 with 3.73 gears.
    NP 208 with 2.61 low range
    38x12.50 TSL (but they're not really 38" tall)
    Lift It, Lock It, LIVE IT!!!
  15. CK5
    May 19, 1999
    21,623
    701
    CO
    4:88's with 37's and 700R4, I plan on going 38.5/39.5 with 400 auto and doubler so should be about right, if I was going to keep the 700R4 I would go 5:13.
    Steve
    Bandwidth FREE ZONE
    Mall-Running poseur 4x4 with curb-feelers
  16. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Today =front D44 w/4.09, rear D60 w/4.11 on 3- 33" Dunlop MudRovers and one BigObigFoot was 33 at one time....spins about 2850rpm at 60-65 (spedo ain't so accurate andymore)
    Tomorrow = 35x12.50-15 SWAMPERS!!!!!!!!!! YYYYEEEEEEHHHHHAAAAAAAAAAAAAAAAAAAAAAAA
    <a target="_blank" href=http://www.geocities.com/baja/5099>www.geocities.com/baja/5099</a>
  17. white_knight
    white_knight 1/2 ton status
    Feb 23, 2001
    1,171
    Calgary, Alberta,Canada
    410's with 44's, sm465
    The horsepower is saving me for now
    <a target="_blank" href=http://www.whiteknight.scriptmania.com/>http://www.whiteknight.scriptma
    nia.com
    </a>
  18. Adrock
    Adrock 1/2 ton status
    214
    Marlboro, MA
    i got the same as steve. Hey steve... what are you gonna do about lift to clear the fenders for 38.5s? i've been thinkin of goin to 38.5s also. i'm an inch taller than you on lift and i'm still a little worried about rubbage. but i'm not affraid to hack either.. so whats on your mind????
    Adam
    a.k.a. Adrock
    88 Chevy Blazer FI 383
    "With great power there must also come great responsibility" -Spiderman
    "Juggernaut Smash" -Juggernaut
  19. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    I have 3.08's with 35's. It is very high geared but I will be going to 4.56's in the near future.
    Adam
  20. kpanza
    kpanza 1/2 ton status
    Dec 8, 2000
    1,579
    Lake Forest, Orange County, California
    I am running the BFG MT 35s, 700R4 and 4.56 - it is a nice tradeoff, and highway cruising is just about right at 65-70 mph (probably turning about 2200-2300). But I sometimes wish I would have gone even deeper, I think the 4.88s would have been awesome!! When I get 38s, I will definitely step up to 4.88 or 5.13s most likely...
