what gear oil is everyone running?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by therover87, Jan 2, 2002.
  1. therover87
    therover87 1/2 ton status
    Jun 24, 2001
    139
    Long Island, New York
    i am going to be replacing my rear differential gasket tomorrow and i was wondering what gear oil everyone is running, are some companies better than others, thanks.
  2. Sparky87k5
    Sparky87k5 1/2 ton status
    May 6, 2001
    726
    Lynden, Washington, 4 miles from Canada
    I run NAPA 75/90W synthetic in trans and both axles. Haven't had a problem either.
    87 K5, 427BBC,D60 & 14BFF, NV4500, NP208, TSM disc's,
  3. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    penzoil4096
    formerly 77chev
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Mobil 1 here.
  5. The_Sandman_454
    The_Sandman_454 1/2 ton status
    Sep 9, 2001
    209
    Michigan, USA
    Another vote for Mobil 1 full synthetic gear lube here...
    Tim
    &lt;img src="http://bbs.off-road.com/wwwthreads_uploads/53-559733-usflaglargesm.jpg"&gt;
    <font color=red>"Don't Tread on Me"</font color=red>
  6. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Redline shock proof gear oil. Thats stuff works so good that it sticks to things that havent moved in a couple days. Definatly worth the money.
    86Jimmy 4"&35"MTRs,87 burb 4"&33"MT,69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  7. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Grape sented synthetic.
    G.M. P/N 12378261
    <font color=blue>Wow Factor
    A SBC at 6000 RPM, Piston speed of 60 MPH.
    3- The intake charge reaches a speed 4 X greater than the piston.
    Thats 240 MPH.
  8. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    ok let me be the moron and ask what in the world grape sented synthetic is??? [​IMG][​IMG]
    <font color=blue> Jeff - may the force be with you</font color=blue>
    <a target="_blank" href=http://coloradok5.com/gallery/Jeffs-Stuff>link to k5's</a>
  9. therover87
    Jun 24, 2001
    139
    does it have to be synthetic?
  10. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I run Valvoline Dura Blend in mine, 80w-90
    it doesn't have to be synthetic, but you don't have to worry about it as often as you would if you ran conventional stuff. Plus, it keeps it cooler, so the diffs last longer.
    90K5
  11. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    It doesn't have to be synthetic but synthetic lasts longer and generally has superior qualities to dino juice. I think you generally should change to it after a rebuild (or very thorough cleaning) so that it is not contaminated by the old stuff.
    Russ
    85 K30 CUCV, 350 TBI, TH400, 205, D60/C14, 4.56 Locked
    Some day: 4" lift, 44" tires, massive cutting, shorter wb and rear overhang.
  12. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Jeff, you must have missed this one.
    <a target="_blank" href=http://coloradok5.com/forums/showflat.php?Cat=&amp;Board=blazer4x4&amp;Number=299812&amp;page=&amp;view=&amp;sb=&amp;o=&amp;vc=1>http://coloradok5.com/forums/showflat.php?Cat=&amp;Board=blazer4x4&amp;Number=299812&amp;page=&amp;view=&amp;sb=&amp;o=&amp;vc=1</a>
    Russ
  13. blk87K5
    blk87K5 1/2 ton status
    Dec 26, 2001
    1,290
    Lubbock, Texas
    I believe that synthetic breaks down slower and is easier on moving parts due to the smooth structure of the man-made molecules, compared to the rough texture of fossil based lubes. I run Amsoil synthetic gear lube. My $.02.
    '87 K-5 w/ 350 TBI, 700r-4, Atlas II, D60 & 14Bolt, 6" susp., 1" ORD body, 35" Claws
  14. The_Sandman_454
    Sep 9, 2001
    209
    Michigan, USA
    I prefer synthetic because it'll actually flow in cold temperatures, better than dinosaur juice anyhow...
    Tim
  15. 3car
    3car 1/2 ton status
    Dec 16, 2001
    976
    Hernando, Florida
    redline
    eatin'fords and shittin'dodges down in the sunshine state.
  16. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I run the syn. stuff in my s-10 but in the blazer I run the cheep stuff that I get by the gallon in 80w120 (the thick stuff). It costs too much to run syn. when I have to change it out all the time because I get water in it.
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
    <a target="_blank" href=http://community.webshots.com/user/triaged>See it Here </a>
  17. sinchphoto
    sinchphoto 1/2 ton status
    Mar 7, 2000
    366
    Southern California
    my buddy that does rear and front ends uses Torco oil I forget the grade.
  18. ABO
    ABO Registered Member
    Jan 16, 2001
    77
    The Burgh
  19. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Thanks for the link Bad Dawg. Saved me the trouble. (I'm still giggiling over it!)
    80/90, stanfdred gear oil.
    That stuff has been used since for-ever! It works, and works well. There is really no reason to step-up to a Synth-blend ($$) unless the rear gears are under-extream stress or your looking for maximum MPG.
    75/90 Full Synthetic.
    It is installed from the factory on the new G.M. trucks ('00ish and up) It has superior lubrication and thermal stability. I would assume, because of the better lubrication, it would reduse friction, and increase MPG, and thats why the Genneral has desided to use it (even considering the extra-cost). The factories are always under constant pressure, from the government and consumer, for better MPG. So, If G.M. installs it (and I can assume why) than it probably works.
    I'd fill it with 80/90 if it's under "normal" use. The gears look good, your not towing with a 10-bolt, your not tring to expiremint with your MPG rating, Ect... or if you dunk your rear axle under-water, like when unloading a boat, because, you should assume, the rear axle will take in water and will need to be changed sooner. So, in the long run, it will save some money in the long run.
    Use 75/90 Full-Synth in the rear, if you plan on towing, or the gears are "ruff" (It's worth a shot, or atleast dealy the R/P swap) Or you expect to use it under "heavy-use". It will -probably- will hold up better if contaminated with water, but the money involved to change it-out doesn't "pan-out".
    -IMO-
    Thats 240 MPH.
  20. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    oh BadDog, how in the world did I miss that post??? ROTFLOL!!! [​IMG][​IMG][​IMG][​IMG][​IMG]
