What gear ratio will work best for me!!!
Discussion in 'The Garage' started by buckmtn, Feb 25, 2007.
  1. buckmtn
    buckmtn 1/2 ton status
    Oct 17, 2005
    288
    Stokesville,Va
    I have a dana 60 I'm in the process of rebuilding and need some opinions on what ratio to go with. My 89 k5 has the stock 350, sm465,205, and I'm currently running 38's but may run anywhere from a 38-42 inch tire in the future. 14 bolt rear is geared 4.10 but my dana 60 is 3.73. Only driven on street to nearest wheeling spot. Trail crawling ocasional mud bog.
    -keep 4.10 in rear and pickup used set for front
    -pickup used set of 4.56 take outs
    -rear gear both to 5.38(new cost $400+-)
  2. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,228
    485
    New Hampshire
    I say then if its only very short street drives then go for 5.38s
  3. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    4.10 and lock the front at the same time. Gearset should be almost free.
    You don't need a super deep gear with the 465 trans. If you do, you'll be cursing it anytime you hit the highway.
  4. buckmtn
    Oct 17, 2005
    288
    Stokesville,Va
    Well I know with out a doubt picking up a set of used 4.10 for the dana 60 will be the easiest and cheapest but I only want to do this once. It does crawl pretty good with granny low and 4-low. Will the motor run at very high rpm on the street with the 5.38 gear and this tire combo. Everyone seems to always want deeper gear than they have. Any more opinions?
  5. 5trucks
    5trucks 1/2 ton status
    Aug 12, 2005
    169
    Yuma Az.
    Do they make 5.38 gears for the 14 bolt? I thought they only went as low as 5.13.
    Wow they do, wish i would have known that before i posted, now i look we todd ed.
  6. bigblazer87
    bigblazer87 1/2 ton status
    Dec 20, 2006
    333
    Elk Grove, CA
    I'd go with 5.13's, but if not, do the 4.56's. If you use the 4.10's and swap on anything over a 39.5" tire, you'll kick yourself in the butt.
  7. Chevy305
    Jan 23, 2006
    11,228
    485
    New Hampshire
    ya sofa king we todd did...
    :haha: :haha: :haha:
  8. buckmtn
    Oct 17, 2005
    288
    Stokesville,Va
    The 4.56 option is a good one because you can pick up a set of used gears fairly cheap for a hundred bucks or so. The question is, is it worth the extra money to put either 5.13 or a 5.38 in it. I want to keep my low end grunt but still be able to spin the pee out of them in the deep mud with out over revving the motor. On road manners do not really matter to me much at all. 80% trail 20% road.
  9. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    im running 4.56's with my 40" hawgs.. .(38.8") true measurement on 16.5x12 rims.... and they work good for me.... a guy that lives a street over from me has a k5 on 44's with a 400hp 350... he said he has no problems spinning his tsl's with 4.10's!!!!!! I think you are good with 4.56's, 4.88's or 5.13's.... I may think you would be better for 4.88's....
    I knew a guy that had 42's with 4.88's and loved it....
    someday I will be on mogs so 6.something for me!!!!! unless I could find the rare 1988 5:08's in a mog.... :bow:
  10. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i dont think the 5.38s are direct in swap for the 14b. id just stick with 4.56 or 5.13's
  11. crazyhole812
    crazyhole812 1/2 ton status
    Jul 6, 2005
    228
    missouri
    i have the same drivetrain in my truck. i am also running 42's. i went with 5.13's
  12. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    I'm running 37's and going to 4.56. That should be plenty with your setup.
  13. buckmtn
    Oct 17, 2005
    288
    Stokesville,Va
    Yea I have read somewhere that the 5.38 gear was a bi*%h to put in the 14 bolt. If I pickup a set of used 4.56 gears I probably have to have the carrier also for the front and rear since I have 4.10 now. In the long run I would just as well of to get the 5.13 gears that will fit the carrier that I have. Thanks everyone for their ideas!!!:D
